P&P'ed 5.3 vs. 5.7 P&p'ed
I have been looking at 5.3 heads and was wondering how they flow stock compared to the 5.7 241's? I have my 241's p&p'ed but was wondering if I got 5.3's p&p'ed with the smaller cc chamber if they would add my hp?
Originally Posted by orangeapeel
Don't change the valves. You will end up having to get all new hardware. Gets expensive. They will have more machining to do and lapping the new valves in.
Bigger valves do not always equal more power. That is a common misconception on here. Keep them stock.
Maybe I'm missing something here, but it just seems pointless to port a head with that small of valves and not replace them with larger ones. ?
Mike
ЯєŧąяĐ Єl¡m¡иąŧøя ™
Originally Posted by SUTTERERMAN85
arent the 5.3 and 5.7 the same intake runners? just with with the smaller cc and smaller valves? FWIW gunnar at PP was going to put stock LS1 valves in my 5.3 for no additional cost other than the cnc'ing. he said it was part of it. just letting you know what i know.
so if they have the same intake runners they would almost flow the same as the 241's and raise the compression which would give me more hp in the end even if they werent ported?
I think TSP has come out with a new port for the 5.3 castings. With the 220cc runner they got them to flow 314@600. They tested the heads on a cam only car and picked up 62 rwhp. 460 though an LS6 intake isn't too shabby if you ask me.
https://ls1tech.com/forums/dynamometer-results-comparisons/604283-all-new-prc-stage-2-5-5-3l-head-results.html
