Stock Valvetrain + T1 CAM = bad or good?
Old 11-15-2001, 01:16 PM
LS1Tech Co-Founder
Nine Ball's Avatar
Default Re: Stock Valvetrain + T1 CAM = bad or good?
The stock LS1 springs suck *** and are barely adequate for the stock cam. Yes, you definitely need better springs for any aftermarket cams. The whole reason many LS1s bend pushrods is because their springs are too weak and allow valvefloat.
Tony
Old 11-15-2001, 01:18 PM
Matt98SS's Avatar
you definately need to change the springs. The comp 918s are nice and what I would look at using
69Muscle's Avatar
S.O.A.B! Damn so much for a cheap upgrade. I would also guess I should upgrade the pushrods as well since i'm in the engine right?
Old 11-15-2001, 01:21 PM
LS1Tech Administrator
RPM WS6's Avatar
Received 1,688 Likes on 1,209 Posts
[quote]Originally posted by Matt98SS:
<strong>you definately need to change the springs. The comp 918s are nice and what I would look at using</strong><hr></blockquote>
So are these 918s what everyone is using now instead of the 941s? How much lift can they take.
Ragtop 99's Avatar
[quote]Originally posted by 69Muscle:
<strong>S.O.A.B! Damn so much for a cheap upgrade. </strong><hr></blockquote>
That's why the LS1 Hotcam kits are popular. Package price is $200 - $300 cheaper than most other cam packages.
I like the T1 better, but it is an option
Old 11-15-2001, 01:23 PM
69Muscle's Avatar
HotCam works with Stock Springs? Isn't it half the horsepower of the T-1 though?
Old 11-15-2001, 01:25 PM
LS1Tech Co-Founder
Nine Ball's Avatar
Hotcam comes with its own springs, which are only a little better than the stock LS1 springs. Those should have been the stock ones on our motors.
No need to change pushrods, but it would be a good idea anyways.
Don't skimp when it comes to internal work on a motor. You typically get what you pay for, and these components are pretty cheap. We are talking about cars themselves that cost well into the $20K range here.
Tony
Old 11-15-2001, 01:40 PM
69Muscle's Avatar
What does a normal shop charge for install of a Cam and springs? How many hours typical? (Just an estimate)
Since I have Zero expereince working on the inside of an LS1 engine i'd probably have CarTek put it in.
Thanks
Old 11-15-2001, 01:47 PM
flyin red TA's Avatar
I have heard of $500 in labor to do a cam and springs.
Old 11-15-2001, 01:59 PM
69Muscle's Avatar
$500!! IS that dollars or yen?! Maybe i'll try it myself! Although I'm sure a good local garage can slap that in.
I can build servers from scratch, I build fiber optic networks without fear, I create webpages using HTML/FLASH/XML why can't I get over my fear of tearing into my engine?! A hillbilly can understand it, why can't I?! <img src="images/icons/frown.gif" border="0">
Old 11-15-2001, 02:10 PM
RPM WS6's Avatar
<strong>$500!! IS that dollars or yen?! </strong><hr></blockquote>
$500 is pretty fair. I haven’t done an LS1 cam yet, but I’ve done an L98 cam. There is a lot of disassembly/reassembly involved that is rather time consuming. Valve train is a little more difficult on L98s though, as you have to keep turning the motor while tightening down rockers, plus you have to pull the intake on those. An LS1 cam swap should be a little easier. But then again, at least on a third gen the whole motor was accessible without going under the cowl!
Old 11-15-2001, 02:12 PM
Matt98SS's Avatar
the LS1 is probably one of the easiest motors I have worked on. The more rear springs are more difficult but get the right spring compressor and its not bad at all. The cam part of its real easy.
Old 11-15-2001, 03:08 PM
66ImpalaLT1's Avatar
<strong>I can build servers from scratch, I build fiber optic networks without fear, I create webpages using HTML/FLASH/XML why can't I get over my fear of tearing into my engine?! A hillbilly can understand it, why can't I?! <img src="images/icons/frown.gif" border="0"> </strong><hr></blockquote>
I do all that too, and I've built several engines, and done one interesting swap. Go for it, you'll never learn if you dont try!
I ordered a T1 cam kit from MTI for $600 last week! <img src="graemlins/burnout.gif" border="0" alt="[Burnout]" />
Eric
Old 11-15-2001, 04:06 PM
69Muscle's Avatar
[quote]Originally posted by 66ImpalaLT1:
<strong>
Eric</strong><hr></blockquote>
It is the fear of it. I know that. If I could of watched someone do it then I would feel better. But to do it on your own...ugh... I burned though a few motherboards before I learned what to do and what not to. Computers are cheaper then cars.
Old 11-15-2001, 04:08 PM
BIGBOS's Avatar
600 that seems a little pricey
Old 11-15-2001, 04:12 PM
Tire Smoking Tranny Blowing Director
Cool28's Avatar
mine was 300 for cam and spring install <img src="images/icons/grin.gif" border="0"> . That was awhile ago though
Old 11-15-2001, 07:07 PM
Fireball's Avatar
69...check with mikey (over in eastern section or whatnot)...I believe he still does them for under 400 smackaroos <img src="images/icons/smile.gif" border="0">
www.rapidmotorsports.com <img src="graemlins/burnout.gif" border="0" alt="[Burnout]" />
Old 11-16-2001, 12:25 AM
Red2000SS's Avatar
<strong>I'm just curious of how many have upgraded their springs with the addition of a Cam. Is it needed. I know you can keep the stock programming with the T1, i'm just not sure if Springs are needed.</strong><hr></blockquote>
Install T1 cam with stock valvesprings, rev engine to 6200 rpm stock rev limiter. Stop car and get out. Look under car, and pick up large chunks of metal, that resemble pistons, or connecting rods that have been pushed through the side of the engine block. <img src="images/icons/mad.gif" border="0">
No way you can run T1 cam with stock valvesprings.
Hope this helps... <img src="images/icons/grin.gif" border="0">
Old 11-16-2001, 12:29 AM
[quote]Originally posted by BIGBOS:
<strong>600 that seems a little pricey</strong><hr></blockquote>
Its the current sale. Cam, springs, pushrods.
Eric
Old 11-16-2001, 12:39 AM
Jon
Jon's Avatar
I am fairly certain that I can get a cam package (cam, springs, pushrods) for under 600 bones. Also I get free cam installs and can have my torque converter (when I get it) installed for a 100 bucks or less, but thats because I have an awesome car club and ofcourse I'll turn some wrenches too.
