What size to drill out the TB?
I've heard some different sizes out there, so please list what cam and M6 or A4.
Thanx in advance,
Craig.
You don't have to remove the TB from the car to do this. Just stuff a rag all the way back well past the TB blade underneath it. After you drill, carefully slide the rag back out and the shaving will come with it. Look carefully up into the intake with a flashlight to make sure that it all stayed on the rag.
Thanx,
Craig
blade drilled out to 15/64 I have heard
some have gone to 17/64..
with hotcam and SLP lt's I still have a bit
of idle problems.. but thinking about the
trooper mod soon.
Jason
[ November 18, 2001: Message edited by: Colonel ]</p>
You should also do the idle relearn procedure.
I know at idle, ATAP says for Throttle Position 0.0% and at full throttle 100%... but I was under the impression that I'd get degrees of the butterfly opening and as I understand it's not to exceed 89 degrees or there's too much voltage... right? Is there anything in autotap that tells me how much it's opening at WOT?
Will playing with the start bolt on the hard stop have any negative effect?
I've tried to have the computer learn but it's no use... I've cleared the codes numerous times and pulled the fuses and reset it several times and the codes just keep coming back. The converter has been in for close to 2 weeks now and I've logged on probably 200 miles or so and the codes still keep coming... so I'm convinced something needs to be done.
Another question, could a mass airflow sensor cause this problem too? It dawned on me that I installed an SLP mass air a few weeks before the converter. I installed 02 simms to silence my clogged cats (that come out tomorrow anyway) and then this SES light presented itself but I'm unaware of whether or not it was there before... I will probably swap back to stock to see if that is what is causing it, but COULD an aftermarket MAF cause this "idle too high" SES light?
1) Raise the set screw (torx 15). I think you can only raise it about 200 rpms before it sets an SES lite due to the idle speed being higher than the pcm setting. Also too much and your TPS voltage can get too high and also set an SES lite. I don't like to have the TPS voltage higher than .7 by doing it this away.
2) Drill out the TB air hole. Too much and you have to epoxy it.
I have a combo of both for my car.
