Well I screwed the pooch! Badly!
Cam install gone bad..... I got the cam in and the new LS6 oil pump on..... I took the first spring off on the Pass side(#2 hole) and go to put on the new spring and I stripped out the rocker stud threads in the head about 1/4" deep!
So much for that! I guess I have to buy new heads now
I have already spent $2500.00 on this cam/spring/intake/oil pump swap and I really hate to spend another $2000.00 on a new set of heads, when a new LS2 costs $5000.00.
Any suggestions on what to do?
LS1 Tech Veteran
Install a Helicoil in the stud boss. Life isn't over yet.
You will need to take a rocker bolt with you to an auto parts store and get the helicoil set consisting of a drill bit, a tap, a helicoil inserter and a few Helicoils (maybe 6). Now, you just drill out the hole in the boss (the metal protrusion that the bolt screws into) making sure not to drill too deep. You may want to get a couple of drill bits that are progressively smaller than the one that comes with the helicoil set. That way, you will keep the new hole on the proper axis by drilling progressively larger holes in steps.
Mask the boss off so as to minimize the shavings that fall into the head. Then you create a new female thread with the tap. Get some cutting oil and turn 1/2 turn clockwise, a quarter turn counter clockwise and repeat untill the hole is tapped.
Vaccuum the shavings from around the area where you have been working. Get some red lock tite and put it on the Helicoil and screw the helicoil in. Then break off the little insertion tab. Let the locktite set up for a few hours and you'll be ready to go. You can do the rest of the springs while you're waiting.
When you screw in the valve spring compressor tool on the remaining valves, tighten it snugly, but avoid over tightening and the potential of stripping.
Best of luck! You'll get there.
Steve
Steve
If the heli sets correctly it should actually be stronger than the aluminum threads. I know a guy the use to build on vw motors and he would heli them just because they were stronger lol.
Steve
Steve
If it starts to get hard to turn, relieve the tension by turning counter clockwise.
Good luck.
R/
Frat
you can get PRC heads, springs, titanium retainers and valves, timing chain, and oil pump and a ASP UD Pulley for like $1900.
Closed ex-Sponsor Account
next time thread the stud into the rocker boss until oil starts puking from the threads, you'll see the oil start to seep right before the stud bottoms out
Originally Posted by GuitsBoy
These guys are correct. Helicoil. It will indeed be stronger than the original threads. Some race motors are built with helicoils from the start for this reason.
I'd try a tap before you pulled the head off the car though.
Ben T.
