Results with ETP heads.
Now please p.m. me when you start building those intakes for $1,200, I want to be first in line.
why don't you stop talking outa your ***. Anytime you wanna try to run the rollers thinking you can out power that ls6 intaked 347 motor with your FAST 347 engine feel free to drop in. I'll even pull it for free Mr big mouth.
Just for arguments sake read this testing, prolly one of the most extensive intake testing to date:
http://www.tpis.com/plog/index.php?o...Id=14&blogId=1
This is from a company that modifies LS6 intakes and FAST is still the best. Look at the LS2 intake.
I see, you race dyno's......
I just realized, you have been on the board for 1.5 months and you have over 260 post's. Biz must be a bit slow these days?
FWIW, the attached dyno sheet shows my car going from an LS6 intake with epoxy-ported TB to a Mamo-ported FAST 90 with a Nick Williams 90mm TB. Same dyno, similar weather, 1 day apart. My car had AFR 205 heads, a 215/230 117LSA cam, plus stock exhaust manifolds, stock cats and factory catback.
2013 Corvette Grand Sport A6 LME forged 416, Greg Good ported TFS 255 LS3 heads, 222/242 .629"/.604" 121LSA Pat G blower cam, ARH 1 7/8" headers, ESC Novi 1500 Supercharger w/8 rib direct drive conversion, 747rwhp/709rwtq on 93 octane, 801rwhp/735rwtq on race fuel, 10.1 @ 147.25mph 1/4 mile, 174.7mph Half Mile.
2016 Corvette Z51 M7 Magnuson Heartbeat 2300 supercharger, TSP LT headers, Pat G tuned, 667rwhp, 662rwtq, 191mph TX Mile.
2009.5 Pontiac G8 GT 6.0L, A6, AFR 230v2 heads. 506rwhp/442rwtq. 11.413 @ 121.29mph 1/4 mile, 168.7mph TX Mile
2000 Pewter Ram Air Trans Am M6 heads/cam 508 rwhp/445 rwtq SAE, 183.092 TX Mile
2022 Cadillac Escalade 6.2L A10 S&B CAI, Corsa catback.
2023 Corvette 3LT Z51 soon to be modified.
Custom LSX tuning in person or via email press here.
To be fair to anyone viewing this (correct me if I'm wrong Pat) this gragh did include a swap to a larger 85 mm MAF, but most people who have documented this change (by itself) have seen little gains, not to mention at this power level (low 400 RWHP) it would be even less. Obviously in the low 500's, a swap to a larger MAF would yield greater results because airflow is at a premium. My guess is the MAF was worth three at best here....even giving it five which is probably generous and unrealistic, the gains from the intake are awesome and are representative of what a lot of others I have helped have seen as well.
The only reason Pat forgot to include this info is this test was done close to two years ago ....and the only reason I remember is someone called me on it a few months back (discussing specifically Pat's results) so its fresher in my mind.
Tony M.
You may have optimized the camshaft for use with an Ls6 intake, or you may have simply bottleed up the exahust so the incrementals aren't there. One thing I've found is you cannot assume anything in testing. You need to examine all aspects of your testing methodology.
Let me cite two example.
I know someone who did some A-B testing of an LS6 and a FAST intake in a F/I application. He saw no increase in power switching intakes. He posted up thsoe results. He called Keith Wilson on it, etc... Guess what. He pulled his airfilter off the car and all of the sudden there was a huge jump in power. The airfilter was restricting airflow into the motor so any change was negligible, as the motor was out of airflow.
I know another car that did some testing and got to ~900 crank Hp, and nothing they did seemed to make any difference. They traced it back to the intercooler. They swapped intercoolers and went well over 1000HP.
Those are just two examples I am aware of. The point here is, don't be myopic in your testing methodology. I'm not saying your results are bad, or that you don't have a strong combo. All I am saying is to make a blanket statement as you have when there are plenty of respected tuners who all have results to the contrary brings your findings into question. You may not care, and you may be totally satisfied with your results. You customer may be thrilled also.
All I am saying is I've done a LOT of testing on the dyno and at the drag strip, and I've only gone faster with a FAST intake.
One last thing. Before you get ugly with Erik, you might want to go back and understand that he has CONSIDERABLE history with the LS6 intake. Erik and the guys at SAM were some of the first guys to cut an LS6 into little tiny pieces and totally re-work it. If there is an intake system for the LS series motor, I think Erik and Judson have probably had it on the Orange car and tested it...
As for Tony's results. I posted up, my results were with one of Tony's intakes...
Amen and well put. That was the point I was trying to make 5 pages ago. In other words, we are not questioning your results but we ARE questioning your conclusion.
I am another example of a FAST 90 and NW 90 picking up power over a LS6 intake and ported stock MAF. Here is the graph. Only changes were an untouched FAST 90, NW 90 TB, and a Mezzier Electric H2O Pump. Same dyno, numbers are SAE corrected. Cam is the G5X4, which apparently is a standard split cam, duration in the 240's, lift over .600 on a 111 LSA. BTW, my car is on stock bottom end, stock heads untouched, weighs over 3300 lbs with me in it and runs 10.8's @ 123. Where's my cookie?
P.S. Please don't even respond to the attacks. Just ignore it and continue the discussion with everyone else who is actually interested in why you lost power with the FAST.
Honestly, if it just takes some rethinking of the cam specs to get away with saving $1300, then I think he is on to something here, regardless of what you guys think of his conclusions about why the FAST doesn't work.
-Geoff
-Geoff
He's looking like an idiot cause it "seems" he's one of the only people out there bashing the FAST set up IMHO.
People can't get past the group lynching and see it, though. Those are awesome gains with a stock intake, but because he refuses to ackowledge the FAST intake, he has been villified. Hell, he saved the guy $1300! That is the kind of stuff I want to see.
-Geoff
-Geoff
Now you have this vendor saying you can buy his "special" cam setup and make more power and save 1300.00! It is the best marketing plan I have ever heard so far. "Buy my special cam and you don't have to buy a better manifold since you will only lose power and lose 1300.00!"
What's next - cams that make more power with unported oem heads than aftermarket heads so that if you run better heads you also lose power? I don't think people want these kinds of products since it means the cams obviously do not work. This guy already stated that stuff I have actually running in the nines and low tens on pump gas just can't be true since they have FAST 90 manifolds and wide cams over 240 degrees.
You say he has made massive power and all this mumbo jumbo but we have that same dyno and a dyno jet as well and have made numbers like that and better and it was with the cams and intakes he says "won't work!" How about 500 at the wheels with combos (346 shortblock) that "don't work" (FAST 90 and wide LSA cams) and go over 130 in the 1/4 mile?
The problem is that he is only looking at his final results and then concluding that the FAST 90 is what is to blame. Maybe HIS FAST 90 is messed up or maybe not but there is certainly nothing wrong with the FAST 90 or it's design at all over an LS6 intake.
Fact is you have to weed through the BS to find most of the really good info.
I personally think the fast 90 and the ls6 will hold the ET heads back a good deal.
Thomas
To use a cam with VEs that fight these numbers is a recipe for producing **** poor peak and area under the curve numbers. A 244/248 114 is not going to work as well as a smaller cam with a tighter LSA installed on a tighter ICL. It will make better peak power, but only at the very end of the run while loosing a whole lot down low. Why? It wants to peak much higher than the FAST is letting it, so the curve is like a sine wave that's been squared off.
The other problem is, nobody wants to run a 244/248 on a 106+1 to produce optimal VEs for the FAST. The overlap would make it a total bitch to live with in a 346.
