Results with ETP heads.
Did you adjust any of the engine diagnostics tables relating to airflow error? I've seen issues with those tables personally. In my experience more airflow can hurt power unless those are adjusted.
Nice to see the Mature behavoir though.
Now I've been to quite a few NHRA Pro Stock engine shops and most are one man shops with some serious power going out of those doors. People like Charlie Weston, Al Neal and Bob Ingles do some very nice work for one man shops. Many NMRA Pro Stock and NEXTEL Cup "big dawgs" use their services.
Sorry if you can't deal with the post, but you have the issue, not me.
keep us posted when you take it out, sounds to me like it should move out
He meant look him up on other F-body and speed related boards in the detroit area in Michigan. he has an extremely reputable shop.
The cam used in the corvette is very similar to the cam in my SS (i believe it has a bit more lift and more LSA) but my car with some not so top of the line patriot heads still put down close to 430hp at the wheels on his dyno, and we baselined my car before the cam install, i was putting down 381 with my same combo but the TR224 112lsa cam. i picked up nearly 50hp to the wheels with this cam over the TR224 cam. so take my word if you want that this cam runs, and it has some properties that is nothing like any of the off the shelf cams.
My car runs like a raped ape as well. it's no "dyno" queen that can't run.
I also couldn't care less about your sponsoring here either. After the whole Chris G/APE issue, sponsors and their posts are not sacred cows here.
Have fun with your FAST-bash fest.
If/when you guys do that A-B test could we swap his 90 with my ls6 and put his 90 on my 383(don't have etp heads) to see the differance.
Zach where are those Fast 90/90 vs LS6 test results ?
Here is a recent (last night) correspondance with a customer I sent a ported FAST 90 to....I was just following up inquiring about his results. Unfortunately no dyno numbers yet but I'm sure at some point he will get there and hopefully share the #'s with all of us when he does. He is a member of this board but I didnt want to drag him in or have him feel obligated to post, although I'm fairly certain he will when the appropriate time comes.
Anyway....here is a copy of a few quick emails we shared back and forth. Note my questions are on the bottom....his replies up above.
Same to you Tony!
Jim
Sent: Friday, November 24, 2006 9:57 PM
To: jabz28@comcast.net
Subject: FAST installed yet??
Just curious how you made out...
Happy Holiday by the way!
Cheers,
Tony
Jim
Sent: Friday, November 24, 2006 10:06 PM
Subject: Re: FAST installed yet??
Is the ultimate accelerameter (the butt-meter) quantifying any other changes besidedes the 90/90 set-up?? That would be encouraging if that were the case....
Sent: Friday, November 24, 2006 10:20 PM
Pulls a lot harder upstairs right?
I have personally been involved in a dozen dyno tests with every one showing tangible gains and have helped dozens of others do the same (make sizable power increases) by providing them with a ported FAST. Whats also important to note is many of these applications were very different...strokers, stock displacement, big cams, little cams, etc., etc., not to mention how many others have reported their own independent positive results with ported or out of the box units. Seems to me its a 100 positive results versus a few not so positive most of which seem to be coming from the same shop....
If we were in a court of law the FAST intake would walk and be declared innocent....to many positive results from a variety of sources versus too few negative ones from one or two.
But hey....ETP was in the headlines for what seems like a month....Im sure Craig, Cary, and boys at ET didnt mind the free advertising
And I dont mean any disrespect to Sean at Collins....we all have our opinions and are ovbiously allowed (and encouraged) to voice them here. As a shop owner / engine builder you have to use what works for you....thats why I will continue to stand behind the FAST and am convinced in ported trim its the best polymer intake manifold on the planet for an LS engine, and especially suited to a street/strip application due to its runner length and other attributes.
Hope everyone is enjoying the Holiday weekend...
Regards,
Tony
the other question i have is why is everyone porting a $1200 intake Manifold??? for $1200 ( tb and Intake) I could have one custom made on a CNC machine out of delrin to the exact shapes sizes and tapers that would work without porting.
We will be conducting some test in the next few weeks as we are aquiring and linning up sevral test vehicles. These vehicles are just regular joes and are using off the shelf camshaft that are very popular within this community. We will unabashedly post up the results of those test and get the 3 particpant vehicles when they have agreed to the testing to come on here and confirm the test results and procedures. A few of these guys are Ls1tech senoirs and have been around for a while.
The test will be setup like so
ls6 stock tb
ls6 90mm tb
FAST stock TB
FAST 90mm TB
LS2 90mm TB ( unless i get my stock TB adapter plates made up by then)
this results will be spread across 3 cars and all will be tested. We will break these vehicles into a 3 seperate days of testing so as to minmize variables.
It will unequviacbly answer alot of the questions that are being posed here.
weather they pickup or loose power the results will be posted here.Testing will being late next week.
Our next correspondance....
And our last correspondance....
The way I look at it Keith Wilson knows a thing or two about manifolds.....he's arguably the best in the business or certainly one of. Most of the work I perform to them simply handles a lot of the issues manufacturing a 3 piece plastic intake can create (core shift, panel misalignment, etc.)....while some of the mods I do you wouldn't have wanted to try and cast that way. Bottom line, I have done quite a bit of my own R&D to ultimately arrive at the shape I did, but I am not reinventing the wheel when I port one of these units. I am probably just making it closer to the way their prototype might have been that this deal was cast around....with a few modifications of my own thrown in. Just as sure as Sean (Collins) is convinced a FAST intake doesn't work, I am that confident that they do....stock or properly modified (they just work better modified).
Regards,
Tony
Ahhhhh....Life would be sooooo boring without the Internet.
I'm sure the younger generation just takes it for granted....
1 IVo was not what the FAST wanted
2 the intake had some extrodinary quality control issues.
How the hell can you possiably install the intake manifold inccorectly ?? really think about that ?
