Results with ETP heads.
Ahhhhh....Life would be sooooo boring without the Internet.
I'm sure the younger generation just takes it for granted....
Tony Mamo has proved his worth to the board, you haven't noob.
I wouldn't care if all 3 cars you dynoed lost power with the fast 90, everybody else's results go against yours and I wouldn't think twice about running the fast 90 on my car.
The person who should be suspected is you.
Secondly why should i be suspect I am not the one reaching into your pockets.
Nice numbers BTW!
the reason for this cam in particular losing power with the fast is due to the fact this cam was designed to use every bit the LS6 has to offer. i would rather spend around $400 on a nicely designed efficient cam then spend another what-ever a fast 90/90 costs just to make up for a shitty cam design....maybe i'm a minority cause i can't **** out money??? so i'm gonna keep my LS6 and ported TB
I asked why nobody is making these already ported delrin intakes/tb for $1200 if there so much better than the fast intake?
Now other people port the fast 90 intakes for cheaper, Vengeance Racing, TTP, and others for like $150-200, but Tony charges more and if people don't like it don't have the intake ported by him then.
Tony explained in another post from a ways back that he charges a fair price for the work he does to the fast intake, but why do you even care what Tony Mamo charges for porting work anyway?
And you're in my suspect pool because you had some bad results with the fast 90 for whatever reason and automatically all the other good results shouldn't mean anything since you couldn't make more power.
JRod's links show proof (dyno tests) that the fast 90 makes more power or did you miss that?
Give me a break.
https://ls1tech.com/forums/corvette-performance/607187-465-rwhp-416-rwtq-stock-heads.html
Get a hobby Barney.....
Now other people port the fast 90 intakes for cheaper, Vengence Racing, TTP, and others for like $150-200, but Tony charges more and if people don't like it don't have the intake ported by him then.
Tony explained in another post from a ways back that he charges a fair price for the work he does to the fast intake.
Why do you even care what Tony Mamo charges for porting work? And you're in my suspect pool because you had some bad results with the fast 90 for whatever reason and automatically all the other good results shouldn't mean anything since you couldn't make more power.
Give me a break.
https://ls1tech.com/forums/showthread.php?t=607187
Multiply those numbers by .88 (least difference we've seen with dynojets)and compare them to the charts i posted on page one. thats a pretty big disparity in output.Making 400hp on the dyno i use is a rare achivement rarely matched by most of the HC stuff out there if you don't belive me i can start posting charts from alot of underperforming vendor cars.I am sure they would just love that.
Here's another graph:
https://ls1tech.com/forums/showthrea...98#post5933998
Must everyone's making more power and torque with a 90/90 setup...except you I guess.
Happy Motorin' !!
the other question i have is why is everyone porting a $1200 intake Manifold??? for $1200 ( tb and Intake) I could have one custom made on a CNC machine out of delrin to the exact shapes sizes and tapers that would work without porting.
1. Been there done that, as have nunerous others on this board, a long time ago I might add. Guess what, the FAST 90 makes more power. Both of my test's were done back to back ON THE DYNO and retuned. One on a 346 and a 408.
2. If it's soooo easy to make the magic intake for $1,200, why are you f'n around with a LS6 and FAST intake???? You're a bus. man, why are you not building the custom intakes for people??? For $1,200, people would flock to you if you're this good. Jeez, just from intakes alone you would be busy as hell.
I'm surprised people are actually keeping this thread going.
and good point on Patrick G. and his cam selection just for the f.a.s.t.
2. Its not that hard to make a good intake you just have to be willing to either A use a totally different design or B find a good way to rework the runner tappers lengths and plenum, to wind up with a much higher resonant frequency. This would move the RPM band north. the Wilson breadbox is a good start if you really wanna make HP over TQ. Depends on your engine building philosphy. I'd rather make the most out of the stuff thats on the car since its so well designed to begin with.
Happy Motorin' !!
2.Well, why are you posting at all? Let me sum it up for you. You're F.O.S.!
What gives. Here is imperical proof that a Vehicle Lost power
9one albeit that makes phenomenal power)and you just can't accept that ?? is there something wrong with you ?
1. You made an assertion that wasn't true. I retored by telling you the truth which is that 90% of the cars that hit these rollers don't make 400hp. Its not a lie its true. Secondly some of the vehicles had fast intakes some had ls6 intakes. I can count on one hand out of the of cars we tune every month that actually make that kind of power. Read carefully regardless of intake manifold. It doesn't happen often. We have one client that has figured out the camshaft secret and is making kickass power.
2. I post here becuase i feel like it. why do you post here ?
Just for arguments sake read this testing, prolly one of the most extensive intake testing to date:
http://www.tpis.com/plog/index.php?o...Id=14&blogId=1
This is from a company that modifies LS6 intakes and FAST is still the best. Look at the LS2 intake.
Now please p.m. me when you start building those intakes for $1,200, I want to be first in line.
