Results with ETP heads.
Seems to me there must have been a problem with the set-up....serious port mis-match, airleak, something that would cause the results you described.
Six months ago we tested a stock 6.0 litre with AFR 205 heads (364 CID) with one of my ported intakes and it was worth 32 HP and 20+ ft/lbs over a stock LS2 intake (a ridiculous gain for a manifold swap)....back to back on a deadly repeatable SF902 engine dyno. The pulls were literally 30 minutes apart (the time it took us to swap the intake).
My experience shows the LS2 to be the weakest intake (similiar to an LS1 intake) and that mimics other independent testing as well....dont have time now but the data is available if someone wants to do a search. For me, the FAST has worked EVERY time, either ported or unported, stock or modified heads no matter who's logo is on the end.
I would try to look into what may be wrong with your set-up when a FAST is bolted in front of it....port locations would be my guess but I dont understand why your having issues others havent had. I would also like to see those low results duplicated again assuming the port alignment wasnt far off....backing the original data would be another interesting test IMO.
Tony M.
But in short.....A ported 90 Fast works
Not questioning you just seriously wondering.
Thomas
edit: my new cam is a 240, 244, .615, .625 on a 115lsa
Thomas
I am gonna take a stab here and say that you will be dissapointed in the results.
Thomas
Thomas
See that where an assumption is incorect. Flow is not Flow when it comes to intake manifolds and cylinder heads. Flow is a good indicator but the dynamics of the runner will play havoc with flow in a situation that is very close to being accoustical in nature. Engines are more then just striaght air pumps. they are accustic devices and as such will respond to geometery changes as much as raw flow numbers.Not all geometery changes are good ones. If you change the geometery you change the accustics and if the accustics change in a way that produces standing waves you are going to kill power.
Are you moving the same FAST from car to car?
Are you saying that all 24X cams w/ a wider LSA cams are going to have a problem w/ the FAST or just in stock displacement engines? There's a ton of people running cams like that in 40X motors w/ nothing but positive results.
Are you using the same cam all the time? Same lobes?
I for one have never seen a loss going to FAST intake, just trying to find out specifically what is going on giving you negative results.
