Results with ETP heads.
Old Nov 13, 2006 | 11:47 AM
  #41
Sean Collins's Avatar
The know it all's know it all
Originally Posted by calongo_SS
Huh?
I didn't say there was anything wrong w/ the #'s, they are good. Just trying to figure out the power loss going to a FAST intake.
Ok its not that the FAST doesn't flow more air on the bench becuase it does, it was tested. We figured it would improve power. We could not have been more wrong on the subject.There are some accustical issues with the intake that have nothing to do with overall flow chareterisitcs.
Old Nov 13, 2006 | 12:02 PM
  #42
02sierraz71_5.3's Avatar
Seems to me its more about the parts working well togethor, I see what collins is saying all the cams that put out big numbers with the fast combo seem to have tight angles and smaller lobes(relatively)
You just hear so much more about gains than loses
Old Nov 13, 2006 | 12:14 PM
  #43
SS4Matt's Avatar
i would be curious to see what happens to my car if the LS6 is taken off and used with the FAST setup. then again, most likely the same thing that happened to the red vette in the first post will happen to my car....
Old Nov 13, 2006 | 05:07 PM
  #44
Heres is the FAST VS LS6 dyno sheet. The bottom blue TQ line is the FAST so is the bottom Red Line. Here you can clearly see that the FAST 90/90 induces a harmonic in the intake tract that cuase a substantialy loss in power.
Old Nov 13, 2006 | 05:29 PM
  #45
Slowhawk's Avatar
LS1Tech Sponsor
must be a specific Cam you guy's use. I've done alot of testing back to back and the FAST 90mm setup ALWAYS makes more power across the curve than the LS6 manifolds. Atleast your setups will save the customer money
Old Nov 13, 2006 | 05:35 PM
  #46
Phil99vette's Avatar
7 Second Club
I'd be willing to bet you have a leak with the manifold.
Old Nov 13, 2006 | 05:56 PM
  #47
We went through everything vacum leaks etc. Resealed the intake manifold with silicone blah blah blah no vacum leaks. It just didn't make power. You can see by the hump in the power curve which indicates an issue with the runner design.
Old Nov 13, 2006 | 05:58 PM
  #48
I question this statement immensly. We are pushing the limits of this manifold design with a 347ci motor. On a bigger engine the FAST would most likely perform better but we have seen that not work out either. There was one application with a very tight LSA dragshaft cam that made 3hp more then the LS6 but the car never approached these power numbers. 350tq 390 hp.
Old Nov 13, 2006 | 06:37 PM
  #49
Slowhawk's Avatar
LS1Tech Sponsor
Then,why are you guy's the only one not gaining HP/TQ?Your #'s are good but not huge by any means.It seams like you are trying FAST setup's on alot of cars from the sound of it.
  #50
JL ws-6's Avatar
Race your car!
I dunno how the fast 90/90 would have worked out on the 402/Et240 setup that I'm running..... but I think i will find out how it compares to an edlebrock with an elbow next year... I suspect the edlebrock will make more power, but we will see.
Old Nov 13, 2006 | 06:56 PM
  #51
We have been testing the FAST setups and been consistently disspointed.Its not us but the people need to retune after changing the intake and all it does is looose power.These numbers are extremly good. dynojet numbers consistently come in 16% higher then this particular Mustang 1750de dynomometer.if you adjust for the dynojet numbers the engine is up in HP alot and the TQ is silly.
Old Nov 13, 2006 | 06:57 PM
  #52
The edelbrock single plane ?? i would expect a huge gain in upper end power with that intake.
Old Nov 13, 2006 | 07:00 PM
  #53
vettenuts's Avatar
If this is a standing wave issue, isn't there a frequency dependence? I see the difference between the LS6 and the FAST appears to be parallel throughout the RPM range, I would have thought that this wouldn't have occurred.
Old Nov 13, 2006 | 07:03 PM
  #54
Slowhawk's Avatar
LS1Tech Sponsor
I'm guessing that this is after your Cam package? I can see maybe your Cam design just doesn't use a FAST,but pretty much saying all the H/C cars out there loose HP? I just haven't seen it but I have seen a few cars gain nothing with a FAST because the setup's just didn't need the extra intake flow.
I'm getting into the Dyno HP game on different dyno's. You can go by your's and I'll go by mine
Old Nov 13, 2006 | 07:06 PM
  #55
Slowhawk's Avatar
LS1Tech Sponsor
Truthfully, with a 402ci with ET 240cc heads I would expect static compression around 12-1 with a Cam in the high 240's.Then a single plain intake would shine for 5500rpm and up.
Old Nov 13, 2006 | 07:13 PM
  #56
No this is with a wide variety of h/c packages. As for using a FAST/LS6 I think we are using up every bit of this intake design in a 347 application.What i know about this dyno is that when you quarter mile sim its always runs the number so i takes it output as being absolute.
Old Nov 13, 2006 | 07:15 PM
  #57
I don't think the runners are that good. There are some shapping things in the FAST that make me go Hmmmm. I haven;t had time to really research the issue. When i get some down time i plan on trying to figure out the problem and if there is a solution.
Old Nov 13, 2006 | 07:51 PM
  #58
CLHAKA's Avatar
Question leak?
Huh?
Could it be the Valley Cover Bolts? FAST uses specific low profile mounting harware...
Old Nov 13, 2006 | 07:55 PM
  #59
Slowhawk's Avatar
LS1Tech Sponsor
Or maybe the throttle body's never reach 100% because the cable Cam isn't cut to clear the PCV setup
Old Nov 13, 2006 | 08:05 PM
  #60
We have checked all those things. the FAST just doesn't make more power from what we have seen.
