Results with ETP heads.
and Zach said they have a LS6 with those results.What do you do at CollinsAuto anyways????
From another thread you were on and this one I'm starting to suspect
there is no claim the Car LOST POWER. Period.
C'mon, guys
There are a few shops here that have done back/back testing on them including myself. I have yet to see a car lose power with one.Believe me,if they didn't work I'd be right there with you saying they are crap
Now that you are really unknown on this forum and present to be a shop that specialize with these cars,I would think you will jump onto being a Sponsor here to maybe get alittle respect
Think about this for a minute.....How many really high powered LSx engines on this board that we have read about, seen dyno, run hard at the track, etc....how many aren't running a FAST 90/90 (ported or otherwise)?? I mean seriously....are there any??
How many guys have we seen do the swap only to show the typical stronger dyno numbers and (most) better track times? (more than we could count and yes some might show slightly less TQ from an uported intake at very low RPM's on a stock displacement build).
Hell....I wish there was a better alternative currently....maybe my 383 could muster 550 RWHP (with a low 240's duration and a wide LSA for better idle quality and drivability).
Anyway....I can respect anyone who's willing to step up to the plate in light of a lot of controversy and opposing sentiment and pleading their case (kinda like three years ago when I was trying to convince everyone a legit 300 CFM port with a small cross section would make big power on a 346)....but the bottom line is there has simply been too many independent results by tuners, shops, and average Joe's that refute the data Collin's is so emphatically trying to share with us. Maybe he is just someone thats messing with everyone to get a rise out of the board....I dont know but Im thinking that's not the case which leaves an even weirder scenario (why arent the FAST intakes showing the same results for him??)....LOL
This thread has certainly been interesting at the very least....but like I said....seems a little like something from the hot rod twilight zone.
Don (Slowhawk) is about ready to bolt on an LS2 intake though....I can tell
Tony M.
How many guys have we seen do the swap only to show the typical stronger dyno numbers and better track times? (more than we could count and maybe a hair less TQ from an uported intake at very low RPM's).
Tony M.
. We are not talking about dynojet HP generated numbers which I have stated at least sevral times in this thread as being at least 15-18% higher then Mustang numbers.If you generically rescale the Mustang numbers up using the most conservative 12% difference this thing is silly. I wish i was joking but I am not going to let people who are not in the loop on this particular project just spout random comments. There are sevral issues with the FAST vs the LS6 comparison.I would say not all engine will respond well and I would definately agree that CAM timing could play a critical role in why. But what does that really say overall about the performance of the FAST when the CAM timing is constant and no other changes are made Aside from trying new spark and fueling values ? It paints an interesting picture which should be openly discussed.The FAST may not always be the best choice. As for the 240 with a wide LSA are you guys getting this kind of power out of a 347 ? Not saying this to be rude just asking a question.Never forget LSA should be the last thing decided upon in a camshaft design.Thats how that mountian of 347 TQ got put down.
As for the small cross section 300cfm port. I might be able to retest this car with different heads. Care to throw a set into a comparison ? I have seen your head on the flow bench it definately flows 300cfm. Just haven't used a set yet.
Got a copy of that sheet ?
Thomas
Thomas
They already are the second set of HP and TQ curves is just down that much in power.
