Results with ETP heads.
You keep saying you lost power with the FAST. My question is this: Compared to what other intake did you lose power??????
MAF frequency for a CL tune or VE table for OL tune?
If that's the case, then I think you have other issues and it's not the intake.
) We are swapping the FAST 90/90 onto the car today, I will post up the GAINS and disprove this immediately.
Thank You.
-Geoff
We had a fast 90/90 pick up over 30 on a 98 H/C car last week coming from the LS1 manifold.
Thank You.
Christian
The only reason why you might lose hp with the FAST is if you left the stock valley cover bolts in and made a hella vacuum leak when you bolted the intake down!
Thank You.
According to your post # 74 you were suppose to post the results of your Dyno test in TSP with the FAST 90 swap over the LS6 one two days ago....
Does your silence means that you have some bad numbers recorded from the swap of intake to share with us???
Christian
Now to some peoples credit on this board, it has been said to determine the hp at the track. Prior to putting the FAST 90 on it, the best the car ran NA was in the 12.50's. This was at Lapeer and anybody who has run at that track knows it sucks. We just went back up there 2 weeks ago and the car ran a best of 12.265 with no VHT on the track and spinning like hell launching. It was also pulling at the top lilke it had never pulled before. So in that case, I think the FAST did improve the performance. It just lost horsepower and torque. Some will say "what was the temp on both days" Well the first time when it dyno'd 416 to 425 it was 67 degrees. The second time it was in the high 40's low 50's. So it really should have been better the second time.
