what should I do to a cam prior to installing?
Some folks use oil...
The stock coating? dont worry about it.. it aint hurting nuttin'.
What cam did ya get?
pin is in real good.. and if its a hotcam
to assure that its been tempered by noting
a blue from heat mark on the lobes..
Terry
http://ls1info.com
Very handy for all the work you have coming up.
We coated our in oil and they went right in. Lubes can sometimes clog the oil pump.
"Helms instructions for removing the engine:
1. disconnect the transmission
2. remove engine"
hopefully I'm not violating copywrite....
<strong>"Helms instructions for removing the engine:
2. remove engine"
</strong><hr></blockquote>
That sounds more like a Haynes manual than the Helm. The Helms manual rules, Haynes sucks. Bad.
I clean the cam with brake cleaner, then lube it all over with 30 wt oil. With a roller lifter motor, no need to use assembly lube on a cam swap.
-Andrew
Well, except for that time when I was young and dumb and assembled a motor with STP.....
[ December 06, 2001: Message edited by: Jax White TA ]</p>
