Go with 114 LSA or 115 LSA?
Old Dec 21, 2001 | 09:21 AM
AgaveCorvette's Avatar
Default Go with 114 LSA or 115 LSA?
cam: 212/212 duration, 525/530 lift
I will be using Stage 1 heads, and this is a street car.
Old Dec 21, 2001 | 09:23 AM
RyanJ's Avatar
SSU Moderator
Default Re: Go with 114 LSA or 115 LSA?
honestly id go with something bigger. 22x, 114
Old Dec 21, 2001 | 09:25 AM
[quote]Originally posted by RyanJackson:
<strong>honestly id go with something bigger. 22x, 114</strong><hr></blockquote>
I thought about 218/218 525/530 114 ...
22x is not going to work for what I want to do.
Old Dec 21, 2001 | 09:48 AM
RyanJ's Avatar
SSU Moderator
looks good to me. why wont the 220-something not work. dont say its the heads....they work fine with stockers.
Old Dec 21, 2001 | 11:07 AM
Ragtop 99's Avatar
I had the 218/218 114 .561 112 I/C. With the idle raised to 850 it felt pretty much like stock and at 900 rpm it was smoother than stock. I used 6300 shift points. I had programming and it was a very good choice.
For 212/212, I would use 114 unless you are trying to keep idle at stock. Depending upon your converter selection, 113 might give better torque if you keep the stall down.
Old Dec 21, 2001 | 11:24 AM
I have an M6, so no converter. <img src="gr_images/icons/wink.gif" border="0">
Old Dec 21, 2001 | 11:27 AM
<strong>looks good to me. why wont the 220-something not work. dont say its the heads....they work fine with stockers.</strong><hr></blockquote>
Because I don't want that much duration. <img src="gr_images/icons/wink.gif" border="0">
Old Dec 21, 2001 | 11:54 AM
LS1powerN20's Avatar
If those are your only two choices, I would definitly choose the 114.
Old Dec 21, 2001 | 05:22 PM
Ragtop 99's Avatar
For an M6, definitely on a 114. Your idle will be fine.
Old Dec 21, 2001 | 08:31 PM
Tin Indian's Avatar
Comp Cams "Xtreme RPM" Grind# 3752/3752
This will get you a 218/218 .527/.527 114 LSA
This is what I am planning for an A4, Yank converter / Stage 1 heads / headers car.
I would think that the .527 lift would be easy on springs. The 218 duration would be a good compromise of power/street manners on an A4 car.
Anyone feel the same way?
Ron,
