How to weld titanium exhaust?
Old Dec 26, 2001 | 03:41 PM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
Default How to weld titanium exhaust?
Any special tips???
Old Dec 26, 2001 | 03:45 PM
Terry Burger's Avatar
Default Re: How to weld titanium exhaust?
If you are putting it in the stock location, you shouldn't have to change it much. <img src="gr_images/icons/wink.gif" border="0">
Old Dec 26, 2001 | 03:47 PM
Reckless's Avatar
Super Moderator
Believe you have to use the "trick titanium turd" in combination with the welding equipment <img src="gr_images/icons/wink.gif" border="0">
Old Dec 26, 2001 | 03:52 PM
LS1Tech Co-Founder
So a exhaust shop can weld titanium?
I'm ignoring Reckless aka that guy who's car looks like MINE but I'm faster.
John
11.5 to your 11.19
Old Dec 26, 2001 | 03:55 PM
Reckless's Avatar
Super Moderator
May be some sort of titanium rod for the TIG, but you won't be able to MIG it I don't think.
Take my advice, I'm faster, and soon to be much faster <img src="gr_eek2.gif" border="0">
Todd
Old Dec 26, 2001 | 04:20 PM
LS1Tech Co-Founder
Your best was 11.19 right?
Mine is 11.15.
I am going to put a kit on my car too.
Be afraid there sailor!
Old Dec 26, 2001 | 04:38 PM
Reckless's Avatar
Super Moderator
I'm no squid! Get it right man! Call me Master Sergeant! hehe What kind of kit? I got the TNT F2 on the way <img src="graemlins/burnout.gif" border="0" alt="[Burnout]" />
Old Dec 26, 2001 | 04:40 PM
LS1Tech Co-Founder
You didn't answer sailorman. <img src="gr_stretch.gif" border="0">
What kind of kit? It's the Twinkiller kit.
Old Dec 26, 2001 | 04:55 PM
red ws6 99's Avatar
Tig with the tons of argon gas. It contaminates easily so clean it real well before welding.
Gary
Old Dec 26, 2001 | 05:05 PM
onfire's Avatar
Coal Mining Director
Aircraft Ti (and most Ti rods) have to be welded absent of oxygen....most build a chamber and fill it with a non o2 gas....I don't think you could weld it in the open air. Call Brett at BMR....he has welded Ti before.
Old Dec 26, 2001 | 05:10 PM
U-Luze's Avatar
You would have to TIG it up. Before you weld get a very clean stainess steel brush, clean very throuogly before even welding. You have to use pure argon. This helps keep the porosity out of the weld, another reason is has to be so clean. I kinda acts like stainless when welding, it will warp very easy when overheated. If you have a welder you need to use the Tungson with the red band on it. And be very careful not to contaminate the tip when starting. Its kinda a pain in the *** to weld more prone to contamination than mild steel. Hope it helps.
Justin Hagerman <img src="graemlins/burnout.gif" border="0" alt="[Burnout]" />
Old Dec 26, 2001 | 05:13 PM
U-Luze's Avatar
Oh yea the filler rod is a Titanium alloy you use. <img src="gr_images/icons/wink.gif" border="0">
Old Dec 26, 2001 | 05:21 PM
SilverGhost's Avatar
Motorboater
John still plays with barbie dolls <img src="gr_grin.gif" border="0">
Old Dec 26, 2001 | 06:57 PM
gwj's Avatar
gwj
From: Live Oak, FL - in the woods where the creatures lurk.
As was said, TIG with Ti filler. I would be surprised if an exhaust shop has done this, but who knows?
Old Dec 26, 2001 | 07:14 PM
Louis's Avatar
John,
I weld Ti rub plates for the bottom of the race car, and I built a little lexan house with two holes for my gloves and the torch, and a third for the inert gas, Argon. The red band means that the tungsten is 2% thoriated. a green band means that the tungsten is pure, and I use this for aluminum. I would not trust a muffler shop to Ti. If you can find a weldshop, or a well known race team, they can do it for sure. it will not be cheap, I charge 70$ startup fee, and 70$/hr, minimum just to run a bead, so it will get pricy, esp. Ti. Best of luck. Drop me a line if you have NE Qs.
Old Dec 26, 2001 | 08:43 PM
Reckless's Avatar
Super Moderator
Well I got a TWIN SHOT coming for your ***! 250 wet shot right into the TB <img src="graemlins/gr_punch.gif" border="0" alt="[fight]" />
Where are you getting the Incon from?
Todd
Old Dec 26, 2001 | 11:45 PM
LS1Tech Co-Founder
I'm glad I find this all out now!
I'm looking at a titanium catback for my car. Would be 20-25 lbs lighter than stock.
Reckless, I was kidding, your car is my TWIN. Nitrous is the list at some point in 2002. I want to run 10.5 on motor first.
Old Dec 27, 2001 | 02:07 AM
DCPunkSteve's Avatar
If you are going to be welding in open air, I would recamend that you used a mixture of Helium and Argon. Air Gas Co. has a selection of premixed welding gasses called "Gold gas" that you can find for almost any aplication. Titannium is extremely difficult to weld, and if you dont have experiance in welding stainless, or aluminum with a tig, than you should probably contact a specialist in your area.
