Getting Parts Together for H/C Swap
Old 12-01-2006, 01:56 PM
Ls1Envy's Avatar
Lightbulb Getting Parts Together for H/C Swap
Heres a list of parts that I have, please add anything you see missing.
AFR 205's
Head Gaskets
ARP Head Bolts
ARP Lube
Comp Cam
LS2 Timing Chain
Water pump gaskets
Front engine seal
Front engine cover gasket
NGK TR6's
ASP Underdrive Pulley (Still Looking)
TPIS 90mm TB
Fast 90mm Intake (Still Looking)
New Coolant lines and Plugs for LSX intake
7.4 Pushrods
Fluids
NLP Catch Can
Lifters
Injectors 30LBS+
Old 12-01-2006, 02:02 PM
SLP4CamaroSS's Avatar
intake gaskets? oil ? ported ls6 oil pump
Old 12-01-2006, 02:25 PM
erikthegoalie's Avatar
my the NGK TR6??
thats a plug used for nitrous...If I am correct
If you aren't spraying go with the NGK TR55's
Old 12-01-2006, 02:43 PM
Sneaky's Avatar
x2 on the oil pump....
I'm assuming you already have valve springs "for that cam"? If not..... you need to add that to your list.
Old 12-01-2006, 03:10 PM
Ls1Envy's Avatar
Cams going to be good with the afr springs, I'm gonna port my ls1 oil pump.
Do I really need all the gaskets in the TSP Cam swap kit?
Which ones do I defiently need?
TR6's will be good for my 11:1 CR
Old 12-01-2006, 03:43 PM
WS6FTW's Avatar
Head gaskets are a deffient, front seal and water pump gaskets are good to get to. Also, the fast 90 needs different bolts than your stock intake. I'm assuming those came with the intake?
Old 12-01-2006, 04:45 PM
Irocss85's Avatar
how many miles on your engine? maybe new lifters if high mileage, and if you got the cash now, maybe have the rockers rebuilt or new rockers, again, if high mileage or are planning on rev'ing high. got a 160 tstat yet?
Old 12-01-2006, 07:34 PM
Ls1Envy's Avatar
I dont have a Tstat and my car has 64k on it.
Would a CAI add anything to the overall package?
Old 12-01-2006, 08:33 PM
Mssingkid's Avatar
Originally Posted by erikthegoalie
my the NGK TR6??
Nothing wrong with running 1 step colder on a N/A motor... Esp if you have bumped up the compression. TR6's here also...
Old 12-01-2006, 10:01 PM
dnm12's Avatar
whats the cam specs, lifters could be on there, there is also coolant, oil, oil filter, lots of towels, time, a friend or two, a garage, and some beer of course
Old 12-02-2006, 07:22 AM
Ls1Envy's Avatar
Cam specs are 230/232 114lsa
I was going to start yesterday, even though my heads don't come till next week.
My Dad wouldn't let me though, he said I wouldn't remember how to put it all back together if something happened to my heads.
Old 12-02-2006, 01:22 PM
92SilverSHO's Avatar
get lifters for sure, they arent that expensive.
Old 12-02-2006, 01:36 PM
ls1muscle's Avatar
1) I would get a new oil pump.
2) Oil pump to pick-up o-ring.
12557752
3) If you're pulling the heads go ahead and get new lifters, $99 @ SDPC
12499225
I would also get some blue locktite.
Old 12-02-2006, 03:12 PM
Sneaky's Avatar
Is he right?
Old 12-02-2006, 03:21 PM
TOS98SS's Avatar
Just get the MLS head gaskets head bolt and new oil pump o-ring if you are changing that those are the only ones you need all others are reusable.
Oh and some lifters is a good idea
Old 12-02-2006, 03:25 PM
westxwitesnake05's Avatar
you will need a longer bolt for the crank pulley if your u/d pulley doesnt come with one. it wouldnt hurt to get new arp cam retainer bolts also, they are like $7. Check out ls1howto.com they have a good step by step h/c swap "how to". and they have a list of pretty much everything you will need.
Old 12-02-2006, 05:13 PM
dnm12's Avatar
comp R lifters if your getting anywhere near .6" of lift like me with .581 just being safe on my head swap comp R lifters are on my list for sure.
In terms of H/C look at the order on www.ls1howto.com they do a good job, in other words go ahead and dissassemble for a cam swap and by the time you get there hopefully the heads will show up
Old 12-02-2006, 05:32 PM
Ls1Envy's Avatar
If I Buy the U/D pulley used, can the bolt be re-used?
Why does everyone buy a new oil pump?
Is it just because they can? My oil pressure is fine.
thanks for the help guys.
Old 12-02-2006, 05:49 PM
Ls1Envy's Avatar
Do I need a timing cover gasket or is that reusable.
Old 12-02-2006, 06:01 PM
Mssingkid's Avatar
No it can't be reused as the bolt is TTY (Torque to Yield).
Because u have to take off the oil pump to replace the timing chain. Might as well put a new one on while it's out. Timing cover gasket is reusable, but the front seal should be replaced...
