Thunder 220 or 224 Cam for A4...
Den
I had the Hammer cam on a 112, dyno'd 358hp and ran 12.4 @111.I allmost had a divorse over how bad this cam idled. Next was the TR220-114. Idles like stock and runs 12.0's @113. Either of the TR cams is an excelent choice, but I would strongly suggest getting one on a 114. Hope this helps
http://ls1info.com/camstats/showdata.php
I would not go with the LSA 112 with an A4
if its going to be a daily driver..
If you planned on getting some programming
somewhere down the road that may be ok.
In the summer when you need the AC on all the
time its becomes a pain at redlights..
[ January 01, 2002: Message edited by: Gold Z ]</p>
How did u raise the idle without tuning? Did u adjust the set screw on the TB? Do you get any codes with this cam? I'll probably get Cartek to tune my car on the dyno. But if i can raise the idle with the set screw in the mean time. Thanks for your input. I really like what I've seen with the Thunder 224 112lsa cam.
The 114 doesn't hurt peak power, but may raise where it occurs by 200 - 300 rpm. The 114 is a safer choice from an emissions standpoint.
