Engine destruction pics...
Old Jan 13, 2002 | 11:43 AM
GeorgeC's Avatar
Default Engine destruction pics...
Read all of the details here.
These two pictures show holes in both sides of my block, along with the parts of connecting rod that tried to escape from the crankcase...
Old Jan 13, 2002 | 05:03 PM
GeorgeC's Avatar
Default Re: Engine destruction pics...
WeatherGuy, I've never felt the need to dyno the car, so I don't know what kind of numbers it would put down on the rollers... I had just gotten into 2nd gear when it let go, 6000rpm or so maybe...
M.R., 6900-7000rpm shiftpoints, 7250rpm limiter...
Old Jan 13, 2002 | 06:17 PM
LS1derfull's Avatar
Georgec, how many 7000 rpm runs did that motor have on it? And im curios if you do your burnout at 7000? This would be usefull info.
Old Jan 13, 2002 | 06:32 PM
GeorgeC's Avatar
How many runs??? I have no real idea. I only started keeping a logbook last October, but logged over 100 passes since then. I would figure 300 or more passes on that motor, spinning it to 6700-6800rpm or so, and only 10-15 passes with the new cam and slightly higher revs...
Old Jan 13, 2002 | 06:33 PM
BIGBOS's Avatar
Damn... <img src="gr_sad.gif" border="0">
Old Jan 13, 2002 | 06:53 PM
LS1derfull's Avatar
I think 300 passes and lots of street driving(I assume) is doing pretty good. I have a low 10 second 406 small block that i wouldnt try to get more runs out of than that, before i went thru it.
YOu really should figure out if rod bearing failure caused rod to break. LS1 rods are much nicer than old "pink rods" that i turned 8200 rpm with for many years. I would like to know source of your failure. Thanks
Old Jan 13, 2002 | 08:23 PM
WeatherGuy's Avatar
[quote]Originally posted by GeorgeC:
<strong>How many runs??? I have no real idea. I only started keeping a logbook last October, but logged over 100 passes since then. I would figure 300 or more passes on that motor, spinning it to 6700-6800rpm or so, and only 10-15 passes with the new cam and slightly higher revs...</strong><hr></blockquote>
Whoa - that is a lot of very high rev runs, or you can think of it as 75 miles of full-throttle driving. I feel less bad now that a stock bottom end could take that, especially since you were spinning it to close to 7000 RPM.
Old Jan 14, 2002 | 12:23 AM
WeatherGuy's Avatar
Ugly, ugly, ugly <img src="gr_sad.gif" border="0"> I read your post details on the link to the other thread and saw that you had a stock bottom end, so I am not surprised by the shattered rod. One detail I would like to know, though, is what kind of power (dyno) did that engine have. Also, how fast was it spinning when it went?
Glad you came out of that in one piece. Fires can be a very scary thing to happen.
Old Jan 14, 2002 | 12:36 AM
**DONOTDELETE**'s Avatar
Wow....not good. Glad your ok. How many RPMs were you turning with the stock internals?
Old Jan 14, 2002 | 02:21 PM
GeorgeC's Avatar
[quote]Originally posted by Nine Ball:
<strong>You sure you don't want an MTI 382ci with a few break-in miles on it? Its cheep! <img src="gr_images/icons/wink.gif" border="0">
Tony</strong><hr></blockquote>
Actually, I'd love that, but... I don't think it's going to be in the budget. Maybe if the insurance company is extremely generous with a settlement for everything, and you still have it... <img src="gr_images/icons/cool.gif" border="0">
Old Jan 15, 2002 | 12:00 AM
Nine Ball's Avatar
LS1Tech Co-Founder
Damn George, I read about the fire and such on your drag racing post. Thats horrible! I couldn't imagine watching my car on fire.
Tony
Old Jan 15, 2002 | 12:11 AM
LS1powerN20's Avatar
<img src="gr_sad.gif" border="0"> that sucks
