need help diagnosios
Old Dec 15, 2006 | 03:27 PM
Rob@EFIAlchemy's Avatar
LS1Tech Sponsor
Default need help diagnosios
i thought i had an exhuast leak one of my buddies looked at my car yesterday and said my valves were tapping a couple of weeks ago i was having a problem with my car overheating and spewwing out of my overflow so i changed my stat to a 160, my rad cap and about a week later my car was leaking from the waterpump weep hole. for a while now my car at high rpms kicks black smoke and it backfires coming back down in the rmps. could bent pushrods have blown one of my head gasket causing my car to overheat and valves to not close? if so can i changed my own head gaskets and pushrods i have a pretty good automotive knowledge or i like to think.
Old Dec 15, 2006 | 07:49 PM
mullenh's Avatar
no intake swap? are all mods listed everything you have done? you may try a leak\smoke test those intakes are know to leak and fail and while your at it pressure test your radiator.
Old Dec 15, 2006 | 07:55 PM
LS1Tech Sponsor
yeah thats all, no intake yet im looking into getting the typhoon from professional products
Old Dec 15, 2006 | 09:42 PM
DaddySS's Avatar
Run a pressure test on the cooling system and a leak down on the engine, should tell if there are any problems and where they are.
Old Dec 24, 2006 | 08:51 PM
LS1Tech Sponsor
ok so the water pumps the only thing leaking i had a ticking noise coming from the drivers head its now gotten worse after i changed pushrods hooping for bent ones the noise remains stead as you increase rpms not really louder just faster
Old Dec 24, 2006 | 09:00 PM
The1N_only's Avatar
do a leak down test and go from there
Old Dec 24, 2006 | 09:49 PM
N4cer's Avatar
Haven't you read about them?
Old Dec 25, 2006 | 12:06 PM
LS1Tech Sponsor
yea i read abot them about a month ago they add any new info or is something else go wrong they havent fixed yet
Old Dec 25, 2006 | 12:08 PM
The1N_only's Avatar
i dont think that have released the intake again. They was having problems with the "install kit" and they are going to include thicker intake gaskets... From what ive read
Old Dec 25, 2006 | 12:22 PM
LS1Tech Sponsor
yea i read that while back they where reassessing the install kit with it for the the things that didnt fit right
Old Dec 25, 2006 | 12:34 PM
The1N_only's Avatar
For the money i'd get a fast 90/90 set of and port match it to your heads, which is very east to do
Old Dec 25, 2006 | 12:49 PM
LS1Tech Sponsor
the fast is almost 1k with tb i dont need a tb anytime soon and the typhoon is only 500 bux
Old Dec 25, 2006 | 12:50 PM
LS1Tech Sponsor
back to topic what would make the tick worse
The1N_only's Avatar
or you could get a used ls6 for cheaper than that
Old Dec 28, 2006 | 03:23 PM
LS1Tech Sponsor
how do i check to make sure my lifters are ok?
