Low RPM Cam driveablity?
Im trying to decide on a cam, I have it narrowed down to either
Hammer
TR220
TR224
If I go with either TR cam I will get a 112 LSA
I want to make sure that whatever cam I get is at least livable on the street. I have a friend with a Hotcam and it surges like MAD under 1500, and really sucks at low RPM. I cant deal with that. (well I CAN but I'm not willing to)
I want something that will give a noticable lope at idle, and I wantt he TR224 because I love the way it souds, at least in the sound clips I've heard. And I know it will give me decent power, but being the biggest of the three, the worst low end torque.
I have never had a car that wasnt stock with a cam that small, so I dont know how driveability is with them.
Are all the cams mentioned tame at low engine speeds? I realize they will be lacking in power, but will they surge spasticly like the Hotcam?
If so are 3.73s or 4.10s enough to make them liveable on the street. I already have 3.73s and wouldnt mind going to 4.10s with the raised limiter used with these cams.
I will be using stock heads.
Am I Correct in assuming that all these cams are relatively close in power potential?
On other thing, How do the TR220 and Hammer sound? Are they Noticable?
thanks in advance
Troy
hotcam = -1.5
TR220 @ 112 = -4
TR224 @ 112 = 0
T1 = -3
TR220 has the smallest overlap (-4)
FYI overlap of 98-00 Fbody cam is -24
[ January 25, 2002: Message edited by: Aircooled ]
[ January 25, 2002: Message edited by: Aircooled ]</p>
<strong>FYI overlap of 98-00 Fbody cam is -24
</strong><hr></blockquote>
<img src="gr_eek2.gif" border="0"> That's quite a difference between stock and next least conservative cam.
havent seen to many dyno sheets of cams and stock heads, but they all start at about 2000 which is way too high for me to tell how driveability will be affected. I dont want to drive around at 2000-2500 RPM all the time, that seem slike it would get really annoying after about 2 minutes
anyone actualy have any of these cams with stock heads and a 6 speed? I know there are people out there.
Maybe Ill just get one and see how I like it and go from there
So far thats 2 votes for the TR224, with a possible change to 4.10s (or even 4.30s when i go with a 9 inch)
the surging sounds a lot milder than my buddies hotcam. it felt like i was alternating between gas and brake it was so bad.
anyone with either of the other cams?
