C5R block...
Old Jan 26, 2002 | 12:35 AM
FST01m6's Avatar
Default C5R block...
Does anyone have a link to a site that would give me some info about this block for myself. From what i understand they are going for $6000, but i cant seem to find info about it. <img src="images/icons/confused.gif" border="0">
Thanks.
Old Jan 26, 2002 | 12:46 AM
Samba242's Avatar
Default Re: C5R block...
Katech has them. <img src="gr_stretch.gif" border="0">
www.katechengines.com
Old Jan 26, 2002 | 08:11 AM
BlownC5's Avatar
What are you looking to do? The Stock LS1 block is safe for 700+ rwhp. $6000 for a block is <img src="gr_eek2.gif" border="0"> Later
<img src="graemlins/z06.gif" border="0" alt="[Z06 Corvette]" />
Old Jan 26, 2002 | 09:23 PM
FST01m6's Avatar
[quote]Originally posted by Jon C:
<strong>What are you looking to do? The Stock LS1 block is safe for 700+ rwhp. $6000 for a block is <img src="gr_eek2.gif" border="0"> Later
<img src="graemlins/z06.gif" border="0" alt="[Z06 Corvette]" /> </strong><hr></blockquote>
Im just looking at everything that is indestructable.
<img src="graemlins/burnout.gif" border="0" alt="[Burnout]" />
Old Jan 26, 2002 | 09:30 PM
JUSTINB's Avatar
yup i email katech about that block, and they said 6,000 for the block and 2,000 for the crank that fits in it <img src="gr_sad.gif" border="0"> i think ill just buy the 6.0 block from gm parts for 700
Old Mar 5, 2002 | 01:26 PM
Zeta's Avatar
The C5R is an expensive option.
The ARE price is with a core exchange, that brings the price of the block up to whatever an LS1 block costs. I am estimating the cost at about a 2600 difference.
Anyone know what an 7l short block might be from ARE? I called them but I have not heard back from them.
Old Mar 5, 2002 | 01:37 PM
Mike TexaSS's Avatar
8 Sec Tuner
The C-5R block is already a 427 and its aluminum.
Old Mar 5, 2002 | 01:46 PM
CHRISPY's Avatar
You can buy cores for 300-600 bucks
Chris
Old Mar 5, 2002 | 03:22 PM
RyanJ's Avatar
SSU Moderator
[quote]Originally posted by Mike TexaSS:
<strong>The C-5R block is already a 427 and its aluminum.</strong><hr></blockquote>
hmmmm....you cant get 427cid without a crank can you? i believe stock bore on the block is 4.120". the price does not include a crank as far as i know.
Old Mar 5, 2002 | 03:50 PM
Mike Morgan's Avatar
We've built a couple motors with the C5R block.
They still need all the finish machine work which adds a bit to the cost. They do come with heads and main studs and billet caps though.
So there is some value in the block if you want to build it outright. If you are doing it on exchange then our 427 motor resleeved would be the way to go. For $8195 + core you get a built shortblock with heavy duty rods, pistons and crank. It's assembled, balanced and blueprinted with file fit rings, MMS oil pump, MMS cam and a Hex adjust timing chain.
There is a bit of a backorder currently, due to crank supply issues. If we install and tune the motor it comes with a 2yr/24Kmile warranty.
Old Mar 6, 2002 | 12:46 AM
Zeta's Avatar
To save me from guessing....Are you looking at an iron block from GM?
The story is ARE will have a 7l block. MMS and MTI may have them as well.
I have concerns about the longevity of the ARE MMS MTI resleeved blocks.
Good luck.
Old Mar 6, 2002 | 12:52 AM
RyanJ's Avatar
SSU Moderator
theres not much of an issue with resleeved blocks now a days....but all those shops offer a warranty as far as i know. 2 years, 24k miles. the c5r block IS expensive but you are basically buying a block with re-sleeve dimensions that has not been resleeved. did that make sense? id say that they are about 2k more than a bare re-sleeve block from MTI or whoever. now, the max bore for the block is 4.160" i believe. and i know of a few shops doing re-sleeves as big as 4.150" or so.
Old Mar 6, 2002 | 12:57 AM
CHRISPY's Avatar
A 4.1 bore resleeved block from ARE with top quality sleeves is around 2400 bucks. About 3600 cheaper than the C5R block!
Chris
Old Mar 6, 2002 | 01:49 PM
WhiteDiamond's Avatar
[quote]Originally posted by Mike Morgan:
<strong>We've built a couple motors with the C5R block.
Mike,
Am I reading this correctly...If you get the C5R block, it comes with heads?? If so, is that the 6K price and which style head: LS1 vs LS6?
Also, almost forgot, what does the price come to on the "finish" machine work the C5R block needs? I know it requires a cylinder hone, anything else?
Thanks,
Todd
[ March 06, 2002: Message edited by: BLK 98WS6 ]</p>
Old Mar 6, 2002 | 02:07 PM
99MONGOOSE's Avatar
This combo would be too sweet: C5R block and C5R ported heads, cam somewhat comparable to a MTI R1, 1 7/8 Grott headers, Hogan intake, stage 3 incon kit. Make this motor really turn up the boost. This should well support close to 1000RWHP!!!!! <img src="graemlins/gr_hail.gif" border="0" alt="[hail]" />
Old Mar 6, 2002 | 05:37 PM
Ryan K's Avatar
Pathological Modifier
NO, he meant to say Head Studs.
Ryan
Old Mar 6, 2002 | 07:40 PM
MikeTheNewbie's Avatar
Unless you have a key to back door at Katech you can probably forget about picking up any C5R heads. And even if you did; have fun building your intake....
-Mike
Old Mar 6, 2002 | 10:05 PM
[quote]Originally posted by Ryan Karasek:
<strong>NO, he meant to say Head Studs.
Ryan</strong><hr></blockquote>
Darn, that would have been to good a deal to pass up...I figured he meant something else, but it is worth checking. Maybe they are running a special or something.
Todd
Old Mar 7, 2002 | 12:13 AM
Zeta's Avatar
What company nearest the Midwest sells or installs resleeved engines with a warranty like MMS has?
California just seems too far away.
I think Houston is the closest.
Thanks
[ March 06, 2002: Message edited by: Zeta ]</p>
