Will noncoated headers rust and discolor real bad?
My non-coated FLP headers just have a little surface rust on them after a year. A quick bead blast and they would look new again.
Tony
The problem is with mandrel bent tubes there is oil residue left on the tubes. They don't clean the tubes when they are painted at the factory. So if when you get them you sand blast all the factory new paint off and put a few good coats of high temp paint, on the sand blasted surface, they will last. I have done this several times. The last set I did has gone a year and the paint still looks great. But paint doesn't offer the heat barrier the coating does.
