1.85 rockers, simple question
Old Dec 21, 2006 | 11:11 AM
Area47's Avatar
Default 1.85 rockers, simple question
looking for some that are none adjustable. i can put them on, and forget about them. not having to adjust them every 10k miles.
can be 1.8, not overly picky.
a set of GOOD rockers.
Old Dec 21, 2006 | 11:59 AM
Patrick G's Avatar
LS1 Tech Administrator
They used to be available from SLP (1.85s). They may still be available. I'll keep this open in this section for a short time, then I'm moving this to the parts wanted section.
__________________
2013 Corvette Grand Sport A6 LME forged 416, Greg Good ported TFS 255 LS3 heads, 222/242 .629"/.604" 121LSA Pat G blower cam, ARH 1 7/8" headers, ESC Novi 1500 Supercharger w/8 rib direct drive conversion, 747rwhp/709rwtq on 93 octane, 801rwhp/735rwtq on race fuel, 10.1 @ 147.25mph 1/4 mile, 174.7mph Half Mile.
2016 Corvette Z51 M7 Magnuson Heartbeat 2300 supercharger, TSP LT headers, Pat G tuned, 667rwhp, 662rwtq, 191mph TX Mile.
2009.5 Pontiac G8 GT 6.0L, A6, AFR 230v2 heads. 506rwhp/442rwtq. 11.413 @ 121.29mph 1/4 mile, 168.7mph TX Mile
2000 Pewter Ram Air Trans Am M6 heads/cam 508 rwhp/445 rwtq SAE, 183.092 TX Mile
2022 Cadillac Escalade 6.2L A10 S&B CAI, Corsa catback.
2023 Corvette 3LT Z51 soon to be modified.
Custom LSX tuning in person or via email press here.
Old Dec 21, 2006 | 02:34 PM
Area47's Avatar
it wasn't a wanted add so to speak. more or less looking for something in the lines of rockers, that i don't have to adjust, be it yella terra, comp, crane, jesel. i hate running valves every 10k miles
Old Dec 21, 2006 | 03:46 PM
kenp's Avatar
They all have to be adjusted at the installation to get the lifter preload don't they?
I haven't had to adjust my Cranes since the initial installation.
Old Dec 21, 2006 | 04:51 PM
GuitsBoy's Avatar
Not on non-adjustable rockers with hydraulic lifters. The preload can only be adjusted via pushrod length or shimming. Adjustable rockers should be set in the beginning just to make sure theyre all uniform.
Old Dec 21, 2006 | 05:07 PM
Area47's Avatar
throw a set on, set lash, forget about. none are that simple?
adjustable to me means just that, set them, 10k later, have to adjust them again
Old Dec 21, 2006 | 07:44 PM
99 2500's Avatar
SLP sells 1.85 ratio rockers that look identical to the factory rockers and require zero ajustment like factory rockers. I think they come with an upgraded trunion bearing also.
Old Dec 21, 2006 | 10:59 PM
kenp's Avatar
That's what I meant. You are adjusting the non-adjustible on the initial install.
Old Dec 22, 2006 | 06:40 AM
vettenuts's Avatar
I don't have to re-adjust my Cranes, only when I remove them for other reasons. It isn't required every 10K miles, but it will be during a spring change. Once you know how to do it, its not a big deal.
Old Dec 22, 2006 | 10:25 AM
wavrdr's Avatar
How much lift would going to a 1.85 rocker add to the cam?
I'm currently running G5X3/114 with ETP heads at 59cc with .140 clearance on the intake...Would it still clear?
I certainly would like to get a more LSK'ish type lift out of my current setup....
TIA
Old Dec 22, 2006 | 11:29 AM
vettenuts's Avatar
New lift = current lift X new rocker ratio / 1.7
So if your lift was 0.600 and your new rocker was 1.82, then
New lift = 0.600 X 1.82/1.7 = 0.642
Old Dec 22, 2006 | 09:21 PM
wavrdr's Avatar
How would this lift relate to current clearance...Should I consider losing +.040 or will I still be within safe limits?
Any idea on power increases going with these big lifts over my current setup?
TIA
