PCV idea (I did a search)
1 - Total delete with a breather and caps
2 - Leave it with a catch can or LS6 upgrade as only using a
breather only harms the oil
3 - Don't worry about it.
My question is if this will work: To retain vacuum on the system yet, eliminate oil consumption, use a breather style PCV on the oil fill (or somewhere) that has a vacuum port. Basically just making your own PCV system that is baffled as some of the Breather style PCV's are and runs vaccum through the TB so the noxious fumes that harm oil are still drawn out of the crankcase?
Here is a link to the breather/PCV I am talking about"
http://store.summitracing.com/egnsea...u=P%5FSKU&Dk=1
I do see what you are saying though, I would like more people to chime in on this one...my knowledge is limited on the subject....
I kind of go back to older style SBC's and stuff...they didnt have PCV systems did they? Just a breather usually, correct? Someone fill me in on that one.
What effect do the gases have on your oil?
http://store.summitracing.com/partde...5&autoview=sku
I think I am gonna try it next month in the oil fill hole. I don't know if oil is in my intake, but I know I have consumption at 97K.
That was one of my thoughts as well; however, that wouldn't solve the need for vacuum as some say.
My idea is using a closed, baffled PCV breather in the oil fill tube. Thus closing down the existing lines and making it damn hard for oil to make it into the motor. I agree you need vacuum to clear the crankcase. But my idea wouldn't get oil all over the motor. The oil would hit the baffles in the closed breather and fall back into the motor. The vacuum would still evacuate the oil destroying vapors. It would still be a closed system. It works just like a Gen I motor PCV setup, only the baffles are in the breather and not the valve cover.
