CNC vs. NON CNC Head porting??
Old Feb 21, 2002 | 04:48 PM
SSBoy's Avatar
Default CNC vs. NON CNC Head porting??
Okay,
can someone tell me what the difference is in the two? Obviously i know that one is done by hand and the other is done on a machine, but you would think that the machine is much more accurate/precise right?
My dad, stubborn as he is, thinks that any CNC job will always be better than a non CNC job. I kinda disagree. But then again, im a novice when it comes to stuff like this and just want to find out info from the guys who know there stuff.
thanks guys
Old Feb 21, 2002 | 04:49 PM
Terry Burger's Avatar
Default Re: CNC vs. NON CNC Head porting??
No one has ever written a good LS1 head CNC program, otherwise your dad would be right.
Old Feb 21, 2002 | 05:03 PM
SSBoy's Avatar
Interesting.
Terry,
so with all these CNC machines available on the market, each one is written by a different person per say? So basically your getting that persons porting copied onto a piece of software in which translates to the heads being CNC'd.
Old Feb 21, 2002 | 05:09 PM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
I got to watch the CNC machine do a cylinder head last year at Total Engine Airflow. These are very expensive machines. It takes a lot of work to digitize everything.
Old Feb 21, 2002 | 05:20 PM
Mike Morgan's Avatar
There are probably several LS1 programs out there. They may all differ a bit.
If you look at the LS1 market though, the better performing cars tend to run hand ported heads.
The problem with CNC is if you redesign or improve your port, then you have to start over again and digitize and surface plot the head.
Old Feb 21, 2002 | 05:53 PM
SSBoy's Avatar
I do agree that the majority of people running Ported/Polished Cylinder Heads on this board are probably running heads that were NOT CNC machined.
Do most sponsors on this board CNC there heads or hand port them?
Old Feb 21, 2002 | 06:56 PM
LS1derfull's Avatar
LS1 heads may lend themselves more to hand porting because they dont seem to need as much material removal as older heads. Part of the reason they are so much better than old style heads, GM design engineers cast them closer to a good finished port from the get go.
Old Feb 21, 2002 | 08:41 PM
SSBoy's Avatar
Do the majority of sponsors on this board CNC or hand port you think?
Old Feb 21, 2002 | 08:48 PM
LS1derfull's Avatar
i DONT KNOW BUT I THINK cnc would be safer considering wall thickness of LS1 ports,consistency would make them more reliable.
Combustion chambers need to be identical also so computer doesnt set off missfire code. I plan on hand porting my own but this is for best results and i have lots of porting experience.And a flow bench. <img src="gr_images/icons/wink.gif" border="0">
Old Feb 21, 2002 | 08:55 PM
LS1Tech Co-Founder
The majority hand port.
CNC can only go so far, and they get finished up by hand.
I'm guessing that TEA in KY, and CNC Cylinder Heads in FL are the only ones, unless someone is buying CNC heads from Pete Incaudo and doing additional work on them.
Old Feb 21, 2002 | 08:57 PM
Jantzer98SS's Avatar
Most hand port their heads. The best scenario would be a CNC'd head, of course with a good port design, and then finished by hand to remove all of the ridges left by the machine. Usually when I'm porting I feel like a machine. I get into a rhythem and time just flys by. You have to port systematically so it's difficult to just stop. What you do in one port has to be done in all of them in a row, for consistency anyway. As long as hand porting is done consistently in this way, and done by somebody knowing what they are doing, you can get the ports VERY close to exact.
Old Feb 21, 2002 | 11:21 PM
Mustangkiller7's Avatar
So Jack when are you getting those hea ported?? I am still getting together all my exhaust stuff. I am going to go your way with the FLPs! <img src="graemlins/burnout.gif" border="0" alt="[Burnout]" />
Old Feb 21, 2002 | 11:29 PM
SSBoy's Avatar
Thanks guys for the explanations. I've learned a good amount of info on this topic. I wish learning stuff in college is as interesting as this <img src="gr_images/icons/wink.gif" border="0">
Jeremy,
..just doin a lil R&D on the heads. Prolly wont have them in the future, and if i do it wont be for a long time. your gonna like the FLP's. There not as bad as people make them out to be. Sure you might have a kink to work out with them, but then again what mod is every PERFECT when you install it, ya know. Lemme know if you have any problems with them, but im sure you wont.
take care
Old Feb 21, 2002 | 11:33 PM
383LQ4SS's Avatar
[quote]Originally posted by Pro Stock John:
<strong>The majority hand port.
I'm guessing that TEA in KY, and CNC Cylinder Heads in FL are the only ones, unless someone is buying CNC heads from Pete Incaudo and doing additional work on them.</strong><hr></blockquote>
Many people buy heads from Pete. I was there the other day..you should see the heads that go through there....tons of them... hes a top notch guy too.
Old Feb 21, 2002 | 11:52 PM
John B's Avatar
Moderator
Maybe Nineball can jump in here but I believe the early versions of MTI's fully ported heads started out with CNC heads and then were ported in-house by hand for final tweaking which gained additional flow.
Old Feb 22, 2002 | 02:33 PM
SSBoy's Avatar
So is it correct to assume that getting heads CNC'd by one company is totally different than getting CNC heads done by another company, PROVIDED that they use DIFFERENT softwares???
If i call a local company by my house, would they tell me which CNC software they use or is like an 'exclusive' private thing? Point im tryin to get at is if some company 1K miles from me uses CNC by the same software that the guy down the street uses from me, i guess i could just go down the street? (im sure there are other factors, such as the 'finishing touches'
Old Feb 22, 2002 | 02:35 PM
SSBoy's Avatar
Old Feb 22, 2002 | 02:37 PM
LS1Tech Co-Founder
SSBoy, my point is that I think only two companies (TEA, CNC Cylinder Heads) actually use CNC programs to port LS1 heads.
They do not use the same program. Just the same software.
Old Feb 22, 2002 | 02:38 PM
SSBoy's Avatar
<strong>SSBoy, my point is that I think only two companies (TEA, CNC Cylinder Heads) actually use CNC programs to port LS1 heads.
They do not use the same program. Just the same software.</strong><hr></blockquote>
PSJ, okay i gotcha
Old Feb 22, 2002 | 03:22 PM
Matt98SS's Avatar
basically a place like TEA or joes head porting (made up place) hand ports some heads to find out what works and what doesn't when they get results they want. they strap it on to the CNC thing and it reads the heads so to speak and make plots on a program or file then from then on the CNC machine can make exacting ports to match that hand ported head they were happy with. so its faster and cheaper for a company that has one already say a big mustang place like TEA or whatever. they can just pop it on the machine and walk away.
you would think a place that had one would just buy a big time head like a MTI or GTP and set there CNC machine to copy it from there on
Matt
