Few ?'s about milling, compression, & pushrod lengths
With 11:1, would a 7.3 pushrod be sufficient? Or would I need a shorter length? TIA
Josh
What compresson ratio can you get with the truck heads with .xxx mill?
Sorry for the questions, just good research for an upcoming project.
Todd
[ January 30, 2002: Message edited by: Damian ]</p>
Todd
The aftermarket cams have a 0.030" smaller diameter (I beleive it is diameter and not radius) base circle. So, maybe the heads are milled 0.030" for that reason.
It seems that most people run stock pushrod lengths with that setup. Maybe that is why so they didn't have to figure out an acceptable pushrod length from factory spec's.
Eric
<small>[ March 15, 2002, 02:10 PM: Message edited by: wizkid ]</small>
The concensus was this (all empirical of course):
-Each .005 milled = 1cc loss to chambers
-Max mill for stock head is .050 (just had mine done)
-1cc loss = .13 increase in CR
-.050 mill = 10cc loss to chamber = 1.3 increase in CR
I have 12cc dished pistons, so this would bring me back to 10.0:1 CR with a zero deck height. A good sight to use for calculations is: http://www.prestage.com/carmath/
Using the following fifures in the calculator, you net an 11.5:1 CR:
Stock Bore = 3.9
Stock Stroke = 3.662
Stock Deck height = -.006
Stock gaskets = .054
Combustion chamber with .050 mill (or unmilled 5.3 truck head) = 57cc
Valve Relief = 2cc (I use this because it nets a 10.1:1 CR in the calculator)
Any other ideas?
