Motor is back together, runs like crap...
Old Feb 28, 2002 | 07:04 PM
PhantomTA's Avatar
Default Motor is back together, runs like crap...
So let's start at the beginning...
The car is a 98 TA, and because the oil pump was goin bad we pulled the motor. The idea was to rebuild it and do a ARE head ca swap as well.
I replaced the crank with a brand new one, Clevitte bearings, new rings, new chain etc. The pistons and rods are stock. Had all the clearences checked after putting a new cross hatch for the pistons, and everything was good.
Went with a ARE stage 2 head, and a 226 234 ARE cam. Not mention the ls6 intake, 30lbs svo injectors and various other things..
Anyways, the shop im having do the work got the motor in and started it and it idled fine. We reved it up just a tad and it ran fine.
Weather wasnt nice so they had to wait to take it out. 2 days later it was started again since the weather was much better.
As soon as the car started it started to pop and miss. Fuel was coming from the tail pipe, and we got a check engine light for "LOW MAF FREQ" or whatever.
The MAF is recieving 5 volts to it. thats fine.. it even has signal coming from it. All the wires to and from the MAF look good...
The grounds look good as far as we can tell..
This valve train is NOISY as hell btw.. 150 thou shorter pushrods with 80thou lash caps. Nick at ARE says this is what i should have for my higher compression..
So right now im completely clueless....
Any ideas?
Thanks guys
[ February 28, 2002: Message edited by: PhantomTA ]</p>
Old Feb 28, 2002 | 07:13 PM
Colonel's Avatar
Default Re: Motor is back together, runs like crap...
LTrims & Mass Air Flow Rate?
Old Feb 28, 2002 | 08:28 PM
zombiedude's Avatar
Crank profile relearn done yet? be surprised what that does! <img src="gr_images/icons/wink.gif" border="0">
Old Feb 28, 2002 | 08:54 PM
PhantomTA's Avatar
Stephen,
ahh i knew i forgot something..
Zombiedude,
Whats the relearn? and how?
Old Feb 28, 2002 | 09:12 PM
zombiedude's Avatar
My books are at work,BUT! I'm having to go through The Big Three thing and each 1 is different. THIS AN I THINK! AT HOME WITH BRAIN AT WORK! <img src="images/icons/rolleyes.gif" border="0"> So, here we go. <img src="gr_grin.gif" border="0"> U got to have Road to go to 60mph then let off the gas and coast to (can't remember) 40,30 or 20. #3 TIMES IN SUCSESION! Could be 15 mph. Like I said, books at work. So u found a road u can do this on. Go to 60mph, let off gas and COAST to 20mpr.COAST! DO NOT HIT BRAKE! Three times. If u hit the brake, it remembers ur last. Do it three times. Then it Relearns ur crank Profile. Like I said. I can't remember which Lowwer mph's so im going with the lowest, 20 mph. I will Look in my notes and post. <img src="graemlins/gr_cheers.gif" border="0" alt="[cheers]" />
Old Feb 28, 2002 | 09:17 PM
PhantomTA's Avatar
im really afraid to drive it actually.. but we'll see..
thanks
Old Feb 28, 2002 | 09:30 PM
zombiedude's Avatar
I over looked ur noisy thing. Knock retard. <img src="graemlins/gr_judge.gif" border="0" alt="[judgement]" />
Old Mar 1, 2002 | 12:31 AM
BLOWNMERO's Avatar
Whats the reason for the crank profile relearn?? I just rebuilt my motor, and have yet to put it in. Am I gonna have to do this as well??
Old Mar 1, 2002 | 09:50 AM
Dean98TA's Avatar
If it's coughing and sputtering, and it's spitting fuel out the exhaust, it sounds to me like your timing is way off... as if your timing chain jumped a tooth or so.
Check all the simple stuff first though - like the plug wires still on the plugs, coil pack connectors still plugged in...
Old Mar 3, 2002 | 09:05 AM
PhantomTA's Avatar
Ive been sick lately and with work i havnt had a chance to get any info on the car..
but i still open to suggestions..
Thanks Guys
Old Mar 3, 2002 | 10:19 PM
99 Black Bird T/A's Avatar
[quote]Originally posted by PhantomTA:
<strong> 30lbs svo injectors and various other things..
[ February 28, 2002: Message edited by: PhantomTA ]</strong><hr></blockquote>
How are you adjusting for the bigger injectors?
MAFT? LS1Edit? Custom PCM?
Old Mar 3, 2002 | 11:35 PM
PhantomTA's Avatar
maft.
the injectors arent the problem..
Previous heads and cam combo worked fine with it..
Old Mar 4, 2002 | 01:55 PM
TrahnZam WS6's Avatar
Put your stock injectors back in, your car is prolly running like **** since the pcm thinks you still have stockers in.
Old Mar 4, 2002 | 02:56 PM
PhantomTA's Avatar
actually john..
7.250's with 80thou lash caps per Nick at ARE.
and NO its not the injectors..
If it was the injectors then why would the car run for a year with 30lbs and my old head cam combo????
Old Mar 4, 2002 | 02:59 PM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
Dave, who's doing the work on your car?
What have you guys checked so far?
Old Mar 4, 2002 | 03:10 PM
PhantomTA's Avatar
Aggressive auto..
but im not there.. i am kinda relaying what i know. which obviously isnt much.
Appearently all the grounds look good, and the wiring seems good.
i wasnt around for the rest cause of work..
Old Mar 4, 2002 | 04:51 PM
Mark IXZD 150's Avatar
Was the cam lined up dot to dot with the crank? I've heard similar problems and this was the culprit. Worth looking into.
Old Mar 4, 2002 | 05:22 PM
PhantomTA's Avatar
the car ran fine..
now its not right.. how could a cam move after it was ran for 2 mins?
Old Mar 4, 2002 | 05:30 PM
C5 Hardtop's Avatar
Swap out the MAF with one of your buddies.
Joel
Old Mar 4, 2002 | 05:41 PM
PhantomTA's Avatar
already did.. no change
thanks
