My ASP pulley flew off at the track. Should I have any worries? Please help?
Okay, while in the middle of a run, my pulley decides to fly off the car. I dont think I have done any damage but what do I know?
Needless to say the track officials found the pulley, bolt, and 2 belts and I am currently using it but I dont think it is balanced correctly. My question is, can I cause any engine damage with my pulley being "out of balance"? I dont want to take any chances with that harmonic balancer. Reason I am thinking it is out of balance is because every couple days I am having to tighten that bolt up (I used the high strength loctite).
Let me know if I can cause any damage to my vehicle and I will put the beast out of commission for a couple weeks until I find a new pulley.
How would I know if I have already damaged something?
I hope you used a new bolt when you replaced your pulley. That bolt like many others is torque to yield. Also, If you torque it to spec which works out to ~240-250 ft. lbs. It should never come off. Also, be careful when installing the pulley and don't pull it on with the bolt. Use a threaded rod setup to press it on. This will save both the bolt and the treads in your crank snout.
I hope this helps. <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" />
Shane
Shane
The bolt is built to stretch, therefore you should not reuse it. Did you use a new bolt when you installed the pulley?
I wouldn't reuse a pulley that went flying down the track bouncing and scraping the whole way.
One other thing, be very carful with this because you can easily damage your bottom end with an improperly installed pulley.
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by Onyx LS1:
<strong>The bolt is built to stretch, therefore you should not reuse it. Did you use a new bolt when you installed the pulley?
I wouldn't reuse a pulley that went flying down the track bouncing and scraping the whole way.</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">AMEN!!! <img border="0" title="" alt="[Eek!]" src="gr_eek2.gif" />
What kind of bottom end damage can be done?
I used the same bolt but am getting a new one.
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by swtvictory:
<strong>What kind of bottom end damage can be done?
I used the same bolt but am getting a new one.</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">In all probability, you would damage your main bearings. The whole idea behind a harmonic balancer is to dampen harmful vibrations in the reciprocating assembly i.e. your crankshaft.
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by XtraCajunSS:
<strong>Also, be careful when installing the pulley and don't pull it on with the bolt. Use a threaded rod setup to press it on. This will save both the bolt and the treads in your crank snout.
</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Can you explain this? is then when takin off a stock pulley? whenever i have done asp pulley installs it slips right over the crank snout very easily and i would use the old bolt (as instructed) and torque it to spec and then throw in a new one and torque again to spec.
[/qb][/QUOTE]Can you explain this? is then when takin off a stock pulley? whenever i have done asp pulley installs it slips right over the crank snout very easily and i would use the old bolt (as instructed) and torque it to spec and then throw in a new one and torque again to spec.[/QB][/QUOTE]
It's okay to do that in a pinch but I highly recommend using a piece of threaded rod and a nut/wahser combo to get the pulley most of the way on the crank. Once its almost seated, then use the old bolt to seat it. Then use a new bolt and torque to spec. This is the safest method and will not damage the crank threads. Last week there was a thread on here from a guy who actually stripped the threads out of his crank and had to tap new ones!!!
oh okay..makes sense now. Whats the thread size for the rod do you use? sorry..id use the search feature..but im lazy right now <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
I just got off the phone with ASP and spoke with a lady there.
They have AWESOME customer service.
They are shipping me out a new pulley FREE minus the shipping which I got next day so I can have it for the weekend.
I have to send them mine when the new one arrives and thats all.
I would recommend ASP to anyone despite some of the negative things I have heard lately about them.
Take care and thanks for everyones comments.
<strong>I just got off the phone with ASP and spoke with a lady there.
Take care and thanks for everyones comments.</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">I don't know why they'd send you a new one when you installed it improperly (used the old bolt). However, consider yourself lucky that you got a new pulley, I just hope you didn't damage the bearings.
BTW, I would love a picture of this threaded rod to seat the pulley. Thanks.
How would I be able to tell if I damaged any bearings? Is there any way to check?
I know that I dont deserve a new pulley. I didnt call them to complain and get a free one. I simply asked them when they could get me one and told them what happened and how it happened.
I will have to send them my old one though which is no biggie.
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by geniusjester:
<strong>oh okay..makes sense now. Whats the thread size for the rod do you use? sorry..id use the search feature..but im lazy right now <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" /> </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">I'm not exactly sure, I took an old bolt to a local nut and bolt supply and matched it up. I think it's 12MM.
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by 66ImpalaLT1:
<strong>The rod is 16mm. I just bought a meter of class 8.8 from Fastenal. They have a store near me.
Eric</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Thanks for the correction. <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
