cutting pistons
Old 01-24-2007 | 11:55 PM
chevyls1's Avatar
From: where ever i can store my car. (palos hills,il for now)
Default cutting pistons
ok i have seen alot of treads on flycutting the pistons. does anyone know the measurements you need to cut if you are pulling the pistons and sending them to a machine shop? i have the ms4 cam and the ls6 stage one heads with the bigger valves.
thanks
Old 01-25-2007 | 12:06 AM
THE_SUPRA's Avatar
so, you arent talking about chamfering?
Old 01-25-2007 | 12:19 AM
chevyls1's Avatar
i am not to sure with the internals and the terms i don't know what that is. the machine shop guy asked me if i know how much to be taking off i figured someone on here would know.
Old 01-25-2007 | 12:22 AM
chevyls1's Avatar
iam going to have the pistons replaced. is there a piston out there that is already notched out for bigger valves. and if so what size do i need.
Old 01-25-2007 | 05:28 AM
DONAIMIAN's Avatar
If the pistons were comming out of the motor id just replace them with forged ones and be done with it. Forged piston kits can be had for under 500 bux.
Old 01-25-2007 | 05:46 AM
orangeapeel's Avatar
ЯєŧąяĐ Єl¡m¡иąŧøя ™
You don't plan on milling do you? and
Old 01-25-2007 | 05:48 AM
99blancoSS's Avatar
My guess is this guy is confused and thinks he needs to remove the pistons to have them flycut. Which you do no need to. Hope that helps
Old 01-25-2007 | 05:52 AM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
Just need a head with removed hardware. I think you are right. He must think that. I don't know if he knows that a fly cut is just some eyelash reliefs vs. taking an entire layer off the top of the piston.
lol, plasma cut pistons....haha, now that is asking for a problem!
Old 01-25-2007 | 06:10 AM
GuitsBoy's Avatar
Im gonna stick up for the guy... when you see aftermarket pistons getting notched with valve reliefs, they do so on a CNC. Sadly I do not know the measurements, and im sure it would take some careful micing up and a lot of math go get it right.
I will agree with the others that for the cost and effort of taking the slugs out, might as well look into replacing with some forged internals. You can find forged pistons, rings and rods for under 800 if you know where to look.
Old 01-25-2007 | 01:01 PM
chevyls1's Avatar
I Know That You Can Fly Cut The Pistons In The Motor. I Don't Want To Buy The Tool Also I Wanted A Shop To Do It And I Cant Find Anyone That Would Do It I Just Dont Feel Comfortably Grinding On My Pistons. That Is Why I Am Going To Get The Bottem Half Done At A Shop 383 Stroker With All Callis Compstar Parts. Why Not Go Big! I Will Kick Myself If I Don't Do It Now Why I Can Afford It.
Old 01-25-2007 | 01:10 PM
LS1Formulation's Avatar
Whoa. Capitalizing every word makes for a very hard read.
99blancoSS's Avatar
right on, if you got the coin for the 383 then do it!!
