? about T1 and B1 cam
Old Apr 27, 2002 | 03:41 AM
u8dusst's Avatar
Default ? about T1 and B1 cam
The B1 just makes more power up high, correct? So does this mean you have to rev higher to get the same times as the T1?
Old Apr 27, 2002 | 06:46 AM
VINCE's Avatar
Shorty Director
Default Re: ? about T1 and B1 cam
The B1 makes peak power supposedly 200rpms higher than the T1, but the T1 torque comes on a little quicker..
Old Apr 27, 2002 | 10:59 AM
WS6underPRESSURE's Avatar
I've seen the two cams compared on a dyno. the T1's torque comes in sooner and has a slight advantage in peek torque(3-7ft/lbs) but once your up to 4700 rpm's both cams look the same, the HP peek is the same and they drop off at the same point.
So reving higher with the B1 is not needed.
Old Apr 27, 2002 | 02:26 PM
VINCE's Avatar
Shorty Director
My T1 peaked at 6400rpm... All depends on the setup I think..
Old Apr 27, 2002 | 04:10 PM
2000SS's Avatar
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by VINCE:
<strong>My T1 peaked at 6400rpm... All depends on the setup I think..</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">absolutely!!!!
Old Apr 28, 2002 | 12:18 AM
phenyxTA's Avatar
With the T1 my horsepower peaks at around 6200rpm. With the cam, LT's, lid, and Borla I pulled 381rwhp and 375rwtq on a Mustang dyno so I am definitely happy with this setup. That's with the stock heads and shortblock.
Old Apr 29, 2002 | 08:05 AM
TA_2001's Avatar
here is some desktop dyno 2000 calculated data
on the cams..
http://ls1info.com/article.php?sid=63
Old Apr 29, 2002 | 10:38 AM
StreetStalkerZ's Avatar
On my last dyno runs my peak power was 6400-6500 rpms. The T1 will give a slightly better midrange TQ advantage over the B1 but their both hardly noticeable.
