Reverse torquer cam (the other side of the coin)
#181
Originally Posted by LIL SS
One thing to look at for drag racing is the work over time. Example being:
I made a pull to 105mph in my truck that I logged. Here is the time spent in each RPM range:
4k and bellow: 2.3 seconds (20%)
4k to 5,500: 5.1 seconds (44%)
5,500 to 7k: 4.2 seconds (36%)
Total time 11.6
Now this was not a full 1/4 but I was still only at 5,200rpm in third when I let out. By my estimation, I'd probably be at about 110mph at 5,500 which I'm guessing is about where this truck would trap the way it sits.
So if you look at work over time, based on my final gearing, I would want a cam that really works that 4k to 5,500 rpm range but still holds strong to 7k.
Total time 11.6
#182
Moderator
Exactly why I am planing on doing a cam shoot out with a custom reverse split to some of the bigger standard split cams like the TREX, G5X cams, MS4.. I don't ever plan on putting a Fast 90 set up on my truck. The COEF on the new heads are:
Lift --- Coef -- Percentage over stock LS6
.200 - 75.17 - (-8.43)
.300 - 81.25 - (+3.65)
.400 - 78.21 - (+5.89)
.450 - 76.45 - (+5.32)
.500 - 76.04 - (+6.04)
.550 - 75.00 - (+4.69)
.600 - 73.86 - (+2.65)
My exhaust is extreamly free flowing:
Edelbrock 1 3/4 stepped to 1 7/8 HVMC headers
3" x-pipe
Dual warlock mufflers (they have a cut out built in that goes straight through the muffler when open)
The LS6/ported stock TB combo is a restriction and I think my combo will take real well to a reverse split cam.
My thinking is to get the .200 IVO point as early as I can, keeping the P/V clearence in check for all lifts.
Get a semi early IVC point to keep DCR up.
Since my set up favors the exhaust so heavily, keeping a later EVO point will allow me to keep TQ by not bleeding the combustion charge off as early
Have some decent overlap to get the intake charge moving.
I feel I am set on the intake side of things with a XFI 236 106. This more or less mimics the TREX intake valve point but gains DCR by closing the intake earlier (44* ABDC @ .050 vs 50* ABDC @ .050).
The EVO / EVC points are the ones I'm trying to decide on. I figure a XFI 230 lobe would be a good choice, but do I want it on a 106, 107, 108 is the question. I'm leaning towards the 108 to reduce some overlap in hopes I won't polute the intake charge as much with reversion. A 106 obviously would open the exhaust valve later maybe aiding TQ, but possibly at the expense of more reversion, potentially lowering performance with the polution.
3" x-pipe
#183
good info here...alot of guys like myself cant even afford a cam right now but i hope to some day have a cam only (milled stock 243 heads) car myself...but right now im just reading and tryin to absorb as much of this cam talk as i can
great thread guys and pred.
#184
It looks like the TR 230/224 111lsa will be the perfect cam for me, with my mods-AR lt headers,ory,ported tb,lid,e-cutout,slp dual dual cb,stock ported heads, 9in with 4.11 gears......and a good tune.
Thanks predator for all the good info
![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
#185
Formerly 2001c3driver-7/31/10
This is all looking and sounding great. One question I do have is- do ya want the recverse split when yer exhaust is not as efficient as your intake side. Example LS1 with stock cast iron manifolds. If so then I'm all over this...........
#187
Predator great thread man, I was thinking hard about getting a reversed split due to the power under the curve, and after reading this thread i decided thats exactly what i'll do. Having Thunder Racing in my backyard is a plus, but i'd like your opinion on cam selection...
Like i said, i've been thinking about the off the shelf TR 227/224 .569/.563 114 LSA, but this thread got me thinkin about the off the shelf 230/224 .575/.563 111 LSA.
Soo my questions are what would be the differences b/w these two and which would you suggest?? Think something different would be better? I really WANT that magic 400hp number![Grin](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_grin.gif)
Mods will be QTP LT's, 3'' TSP true duals with bullets followed by 2.5'' under the axle out the back, LS6 intake, Ported TB, Lid and of course the cam...
My stock dyno is in sig...
#188
Seing you have a M6 I would go for the TR230/224, better overlap for power, nicer lope and powerband, better undercurve power.
The 227/224 is a negative overlap cam and a bit stealthy.
#189
Hello,
I have been reading everything I can find about cam selection for the last few months. In relation to this thread I am wondering how to determine intake vs exhaust bias flow.
I am running American racing headers, catted y, with hooker cat back. I plan on running stock 241 heads, ls6 manifold, mti lid, p/p tb, and ftra.
So are the ports in the heads the determining factor as to what kind of split on the cam?
Or is it the sum of the parts before/after the heads?
I am looking at small cams for a daily driver, car does not see the track.
So far I am leaning toward something along the lines of the xe-r lobes, intake 216 @ .050, exhaust 220 @ .050, on a 112 with 0 advance ground in.
With 10.98 to 1 scr and a dcr @ 8.6 would this give me a lot of low end for everyday use and fun?
Or would a reverse split be what I would want?
Thanks for all the good info.
Brad
edit to add car is an m6 with 3.42's
Brad
#190
Well you have catted Y so you'd benefit from either a no split or slight standard split.
This is a cam I'd suggest for you.
218/220 .605/.581 112+2 LSA
This is a custom XFI/XE-R cam with -5* overlap, will pass emmissions anywhere.
You mentionned 10.98 SCR, are your heads milled, if not stock is about ~10.1:1
If they are milled you can go a bit bigger.
#191
Thanks Predator
Have not changed heads yet but was planning on 64.5 cc and a .040 gasket.
Thanks
Brad
Edit to add.
I was looking at xe lobes before, not xe-r.
Is it better to run a higher lift as you said or can I run the smaller lift and be easier on valve springs?
eta2. when I check dcr with your suggestion @ 2 deg adv. I get 8.78, when its straight up I get 8.64.
with .040 quench can I run dcr that high?
thanks
Thanks
Brad
Edit to add.
thanks
#192
12 Second Truck Club
ok, i have a good one. how about a 383 stroker with stock 317's and truck intake. long tubes no cats. all in a heavy *** AWD tahoe. 3.73's and 30.5" tall tires. 4l60e with a TT3000. i had a cam spec'd but that was with plans to go with a better intake and heads. but the way its looking i'm never going to get those. i'm lucky to be getting to build the 383 in the first place. the cam spec'd was a 228/232 639/643 110+2 with the intention of better heads and 90/90 set up or such. i have a idea. but i'm sure i'm way off but here it goes: 230/228 612/588 110 maybe with a +1 or so
here it is with 110 +/- 0
ivo 5
ivc 45
evo 44
evc 4
ecl 110
overlap9
i can mil the heads to raise the compression. thats no problem.
ivo 5
ivc 45
evo 44
evc 4
ecl 110
overlap9
#193
Thanks Predator
Thanks
Brad
Edit to add.
thanks
Thanks
Brad
Edit to add.
thanks
#194
Hmmm, in regard to reverse splits i always thought that a head will not flow as well on the exhaust side as it would on the intake, at least for the most part. I probably don't know what i'm talking about but i'm just thinking.
#195
Predator im going to be cam only with the tr 230/224 with bolt ons........and most of the guys in my car club are going to be cam only/bolt ons as well but most of them are running a tsp ms4..........how will my 230/224 match up against them?, i figure ill have more low end since the ms4 is a dog down low.
#196
Avoid racing from rolls and challenge more from a dig. Tune your setup to hook as much as possible (Relocation bracket, pinion angle etc..)
#197
keep thinking along them lines and the engine is gonna inhale more than its capacity.a cam like that should work best with maximum velocity cylinder heads+just enough efficient intake valve size + exhaust primary diameter stepping out as go along the way.its the key to maintaining critical air speed momemtum.
do excessive exhaust porting + or shove big valves on the lsi head for a na car then you got only two choices,throw the heads in the rubbish or run single pattern +victor junior(if they makem + lots and lotsa revs.
ironically i remmember years back on a 5 litre after explaining i didn't give a rats about dynos but rather wanted to maximise ve + torque with enough revs to do the job,the cam grinder came up with a compromised flat tappet solid profile for some very basic heads with very minimal mods from what i remmember
258@50 in 107 /550lift
253@50 in 108 /525lift
+ dialed it in approx 102lc
i never raced that car in the quarter mile officially
but for a 2950lb with 3.08 + 4 speed muncie + very conservative non wheelspin launch it got me to 60mph around 4.5 to 4.7 secs.
and on the test road refferenced track was doing over 190kph terminals+dynoed within 25 bhp compared to one of the best 5.0 oz group a touring car 87 spec carby engine (albeit mine on 95 ron + his on 98 ron + with the bigger valve ducks guts b casting non efi cylinder heads).
conversely in a mag test report in 91 a leading 620bhp+ 5 litre efi holden supercar accelerated to 60 mph in 5.1 secs ( though i dont know if therec was excessive loss of traction,but one would imagine with sticky dunlop slicks it may not have been that excessive anyway)
another 8 litre 454 motec equipped efi quoted @ 700+bhp in a similar car to mine managed the 60 in 5.2 seconds![Grin](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_grin.gif)
them blokes didn't run reverse splits incidentaly.
air speed is everything.
this message will self destruct within 24 hours![Secret2](https://ls1tech.com/forums/images/smilies/LS1Tech/secret.gif)
Heck a stock LS6 head flows as much or more than a fully ported SBC one.
Even though I think I'm pretty well versed in cam tech for LS, I keep being surprized by results that most poeple usually dismiss because it doesn't follow mainstream. To discover new horizons, one has to be able to think outside the box.
#198
One thing I learned a long time ago comming from "old school", when it comes to heads on LS motors, it is a hole new ball game. Quench area, chamber shape, position of plug, shape of runners are all much more advanced than SBC/SBF older tech.
goes without saying.all variables nowadays suggest less total ignition timing for the lsx which suggests a more linear rate of advance and total ignition advance requirements to get the job done.
i like the concept of earlier evc event which allows scope for negative pressure ve,if the timings are optimised to get that exhaust really moving
that would make one interesting air pump indeed.
the grinds you mentioned are the cutting edge of developments in my books
more torque per rpm in the meat of the rpm range + improved volumetric efficiency where needed most + enough rpms to do the job on the track too.
i am more than content with the stock ls1 head dimensions
but like most here not content with the factory camshaft ve as you well know.to me this is the most crucial element to making an orright 346ci engine into a ball breaking bitumen burning torque monster that thinks its a ls7
![Chug! Chug! Chug!](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_chug.gif)
#199
ok my turn for some advice ![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
currently the car is 3200lbs with me in it, should only be getting lighter down the road
slp headers, with 3in all the way back
ls6 intake (that I want to keep, dont care for a 90/90)
th400 with a fuddle 3800
3.73 gears
stock ported and milled 241's from TEA
224/228 comp cam
patroit golds
I currently spray a 150 shot and would like to keep spraying 100-150
my motor pass is current best of 11.49 @ 117
my best n2o pass is 10.85 @ 124 which was when my car was only running 12.2 on motor
the car sees like 75% racing, alot on the street and some at the track
I would like to bring my n/a times down alot and bring my n20 times down some as well.
Should I be looking at like a MTI X1, or like a tr230/224 ? Or something custom or whatever?
thanks!
3.73 gears
224/228 comp cam
patroit golds
thanks!
#200
torquer v2 113-114lc seems a nice compromise,reverse splits are too finicky with the gas.you get enough comp with the tighter lcs + limited timings for exhaust expansions with reverse splits on nos or forced induction,conversely nitrous does a damm god job of speeding up the exhaust so its a good idea to open it up a tad.by going wider lc it allows for more linear expansion with nitrous + more margin for error.
some bias to the exhaust is good but if you want the best compromise
ie more performance no gas and a tad more with gas,you can go a tad bias on exhaust and run a slower rate of advance curve to really perk up the whole deal + make it less sensitive to detonation.even moreso if one runs higher comp which will hand to hand with 230ish @ 0.50 durations
+ if tune right may very well surprise you in the cruisability department too.
