Parts for replacing stock bottom end
raise the limiter to about 7300rpm and shift at 6900rpm. I have the G5 cam and on the dyno my peak is at 6870rpm. I have the shift points at 6500rpm and limiter at 6800rpm and I'm not happy.
Will replacing my bottom end help any! <img border="0" title="" alt="[Mad]" src="gr_images/icons/mad.gif" />
<strong>My cam requires a little more space and I want to
Will replacing my bottom end help any! <img border="0" title="" alt="[Mad]" src="gr_images/icons/mad.gif" /> </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">If you're asking whether your stock short block will hold up at 7000rpm, sure, but who knows how long. The bolts are the "weakest link" (sorry) in that engine. At the very least get some Katech bolts. The best thing would be to cross-drill and nitride the crank, and rebalance with some GOOD rods and pistons.
SC
<strong>Where can I get Katech rod bolts?</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Go to ls1.com and they are a sponsor over there.I beleive the bolts are 122 plus some change.
When I do it I would most likely step up to stronger rods, pistons, bolts....would that be under 1000??
Pistons range 700-800 bucks
<strong>So 700-1000 for rods, 120ish for rod bolts, and another 700-1000 for pistons...so its around 1500-2000 bucks to have a pretty damn good bottom end??</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Pony up $1k for machining and balancing. If you do the measuring/assembly yourself. Add $1500 for a good shop to assemble, if not.
SC
