Doing Cam Install Tomorrow..
Old Feb 17, 2007 | 02:07 AM
  #121
stangkiller2005's Avatar
well ****** wallmart had no pen magnets.. but i picked up a 5/16ths wooden dowel.. ima bout to try it out.... how far does the 24inch rod have to in? to kno if its in all the way.. i dont want to think its all the way in there... and then its not...
Old Feb 17, 2007 | 02:14 AM
  #122
eallanboggs's Avatar
Stay away from the magnets. If a magnet does come off and stick to a lifter you're going to have to be damn lucky to get it out without removing the head on that side. I think I'd try the Russian Roulette method before the magnets. When the wooden dowel comes to a positve stop you'll know it has reached the back of the block. There's no pressure on the lifters during this process and the plastic retainers help hold them up too. The rod is just an insurance policy.
Old Feb 17, 2007 | 02:34 AM
  #123
Yeah...too late for that now...we broke the magnet..and it dropped in ...
jk jk omg. but it did break, but luckily the magnet stayed stuck on valve cover and we got it with needle nose. Couldnt get the left side rod in...so we used the wooden dowel....it went in smooth. I recommend one steel for right, one wooden for left. And good magnets only for the front lifters...if you need extra help. once you get to the back..u risk breaking the magnet. Cam is in..and now on to oil pump and tube....any suggestions?
Old Feb 17, 2007 | 02:41 AM
  #124
Blk97WS6's Avatar
have fun with the pick-up tube bolt!
Old Feb 17, 2007 | 02:56 AM
  #125
yea i got the new cam in and im ready to start on the oil pump..that will be tomorrows objective along with the valve springs.... well im off to bed..stay tuned! ill be online in the morning
Old Feb 17, 2007 | 11:15 AM
  #126
alrite.. i got the oil pump off, and i need to install the double roller now... so i need to take off the bottom crank sprocket... do i just use the old crank bolt and than the harmonic balancer puller???
Old Feb 17, 2007 | 12:04 PM
  #127
I have taken off the oil pump...but i need to get that sproket behind it off..so i can get the one from my double roller on...my pulley puller arms are too short..so i bought a two jaw gear puller...but the arms wont hold on..it seems as if there is no other way around it... what do you all think about just leaving my stock chain and sproket on there...it would make my life a lot easier.
Old Feb 17, 2007 | 01:19 PM
  #128
Blk97WS6's Avatar
how many miles on the car? i would run up to GM and at buy a new LS2 chain. They should carry them there. If not at least go with a ls1 replacement.
Old Feb 17, 2007 | 01:28 PM
  #129
Hell'sChariot's Avatar
x2
I just got an ls2 chain, you can use it with the ls1 sprockets that are on the car.
Old Feb 17, 2007 | 02:21 PM
  #130
well...got this 3 jaw that worked. now we are timing it...trying to align the dots and so forth.... but the double roller cam gear...its hard to get the cam dowle in it.. it slides in easier in the stock one.. any ideas suggestions to an easier way? cam keeps falling back..major problem.
Old Feb 17, 2007 | 02:50 PM
  #131
DaddySS's Avatar
take one of your water pump bolts, put it through the pulley and then into the cam, pull it together, the but the cam bolts in.
Old Feb 17, 2007 | 03:26 PM
  #132
GT Griller's Avatar
Ditto!! Once thats done get ready for the hard part...the springs, i hate dual springs them things will take a finger off!!
Old Feb 17, 2007 | 03:51 PM
  #133
ok...cam gear and timing chain on! dual roller style. Oil pump on shaft...pickup tube in....pickup tube about to be in..just a lil fight. Next...dual springs...it says 2-6 hours to complete. I have the crane cams valve spring "on the car" compressor....any tips for that? Any tips for anything for valvesprings?
Old Feb 17, 2007 | 04:08 PM
  #134
hey if some of the questions i seem to be asking are stupid. than its not me..lol.. my friends is replying when im workin on the car... well rite now im fighting with the stupid pick up tube bolt.. its A BITCH!!!!! dam it.. well the tube is in.. just need the bolt.. than bolt down the oil pump.. and oil pan.. than get started on the valve springs... i was looking at tha crane cams thing.. but what bolts am i suppose to use to hold it to the block? it didnt come with any? am i suppose to use my rocker bolts?
Old Feb 17, 2007 | 04:13 PM
  #135
Old Feb 17, 2007 | 04:36 PM
  #136
GT Griller's Avatar
NO not rocker arm bolts......thats not the valvesrping tool i used but if i remember correctly ur supposed to get some other stronger thicker bolts. Them rocker arm bolts are small.
Old Feb 17, 2007 | 04:50 PM
  #137
The tool didnt come with bolts? wtf!
What I ment to say was use the rocker arm bolt holes with the crane tool.
Old Feb 17, 2007 | 05:09 PM
  #138
Did you have the pump gears out when you installed the pickup tube in the pump? Now you can see why it would be nice to have the pan off so you could loosen the bolt that holds the pickup tube mounting bracket. It would give you a little wriggle room to get the tube in. Since I don't take the pan all the way off(just take the bolts out to gain access to the pickup tube bolt) it sure helps to have the oil pump disassembled. At least that way you can swivel the pump port in the direction of the pickup tube to get it in.
Old Feb 17, 2007 | 05:19 PM
  #139
well this is his friend just updating(who ran a faster time with stock ta hee hee than his bolt on camaro lol ...anyways he gonna get mad lol)
we just got oil pump and pan on...tube put up a fight...but it lost. Now on to springs.i still dont get what bolts to use?
Old Feb 17, 2007 | 05:23 PM
  #140
Blk97WS6's Avatar
i have no clue what bolts you could use. The crane tool should have came with a stronger one. I definetly would NOT use the bolts for the rocker arms, especially if your doing dual springs.
