Doing Cam Install Tomorrow..
your welcome to come help tho!
ill see how much money i can get you for helping out.. i have the crane cams compressor to... so we should be good.. just could use ur professional asistance
This is the TQ wrench I use for the Rockers. And use a quality 5/16 socket! You will strip the rocker bolts if you use a cheapo!
Against my cobra
Ill have video of the *** whipping
You never told me you were going to do it yourself. So Im going to cancel what you had setup today! Last edited by JMBLOWNWS6; Feb 15, 2007 at 07:59 AM.
i thought i told you i was gunna try the install last time we talked... once its done.. ill call you to see when its cool to bring her over for the dyno tune.
oic.. well alrite then..its cool ill see wat i can do... do you kno where locally i can pick up two decent torque wrenches that would help me out? also yea bro please give me a call friday.. ill be working on it.. i get off at 5... u get text messages? ill text u so u can have my new number...
also ima try installing the empty pump body to the pick up tube like u suggested....seems like it would make it alil easier and makes scence...also do i bolt the pump all they way to the block..and than try to get the pick up tube on? or the other way around?
I dont know about the 1/2 for the crank. I will ask one of the guys at the shop if they would lend there's out but we pay so much $ for our tools I highly doubt it. Disclaimer: All tq. specs are off the top of my head so check the cam swap directions on ls1howto.com for the exact specs.
