Thickest head gasket?
Old Jul 16, 2002 | 10:47 PM
DenzSS's Avatar
Default Thickest head gasket?
I know there are several head gaskets available, but which drop compression the most?
Thanks,
Denz
Old Jul 17, 2002 | 05:48 AM
smokinHawk's Avatar
Default Re: Thickest head gasket?
i know cometic has a .125" gasket. thats thick.
i was going to go with a .078 to drop my CR down, but when my mechanic had my engine apart and needed to replace the bearings i decided to drop it by pistons instead. so i sent um back and got the .057" HP series gaskets.
it you need to find out what CR you want buy gasket or whatever use this.
http://www.rosspistons.com/CR%20Calculator.htm
Old Jul 17, 2002 | 08:22 AM
ls1290's Avatar
Dumb Ass Vette Moderator
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by smokinHawk:
<strong>i know cometic has a .125" gasket. thats thick.</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">I believe that FelPro makes the gasket.
Old Jul 17, 2002 | 08:50 AM
DenzSS's Avatar
Thanks guys. I'll try that.
Old Jul 17, 2002 | 03:05 PM
MelloYellow's Avatar
Not sure I'd go that thick. That's a 100% increase. I went with the .078"s here. People bring up the quench height issue.
Let us know how it works out. I've had Zero probs with the .078"s.
Old Jul 18, 2002 | 05:46 AM
smokinHawk's Avatar
cometic make one too then (.125")
but thats huge <img border="0" alt="[kaboom]" title="" src="graemlins/gr_bomb.gif" />
<small>[ July 18, 2002, 05:47 AM: Message edited by: smokinHawk ]</small>
Old Jul 18, 2002 | 09:20 AM
DenzSS's Avatar
LOL. The .125" spooks me as well. I had no idea there was suge a large gasket. I was looking for something more in the range of .078". At least I know what is available now.
Thanks
Old Jul 18, 2002 | 11:13 AM
MDL-01C5's Avatar
I'm about to put the Cometic .078's on, too.
I'm happy to hear you guys aren't having any issues with them...
Are there any tips you'd give on installing them? (they're the multi-layered steel type)
Thanks <img border="0" alt="[cheers]" title="" src="graemlins/gr_cheers.gif" />
Old Jul 18, 2002 | 11:25 AM
Colonel's Avatar
I'm not sure I like the idea of decreasing C/R with thicker head gaskets. Yes, it's the quench area issue that bothers me. Some say you will end up with a higher tendency towards detonation despite the decrease in C/R.
<small>[ July 18, 2002, 11:26 AM: Message edited by: Colonel ]</small>
Old Jul 18, 2002 | 01:48 PM
DenzSS's Avatar
First off--it isn't my car. Just wanted to get that out in the open.
The guys doing the buildup are well aware of the quench area issues. We were discussing that last night. They are cautious, but would like to know what is available should they think it is worth a try. They have built a ton of FI cars (their specialty).
How does an 02 Z06, Katech LS6 Heads/Cam (Blower design heads), ARP Rod Bolts, 10# ATI D1SC, and a huge fuel system sound? Should be an interesting setup. It will have a very conservative tune until the bottom end gets built.
Old Jul 18, 2002 | 06:05 PM
neat's Avatar
I would be worried about the possibility of increased detonation. I guess the only way to know though, is to try it. Maybe an LS1 piston head combo can still keep all the air/fuel centralized enough at 8:1 to keep it from detonating under boost. Good luck, and keep us posted!! <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
