What makes a cam "good for boost/nitrous"? I'm a little lost on the theory behind it.
For example...I've heard that the Thunder 224/224, 114LSA is not a good cam for boost or nitrous. Then I see that Thunder has a 224/227 on a 114 that they say is specifically for boost/nitrous applications.
I thought the reason certain cams were good for boost was that they had less overlap and held boost in the cylinders longer. But a 224/227 on a 114 with more lift is going to have MORE overlap than a 224/224 on a 114. So why is the 224/227 better for boost than the 224/224? Someone explain the physics to me.
Thanks
Thanks
I'm no cam expert, but I think it is because you need more exhaust duration to get out all the air/fuel that you crammed into the chamber with the power adder.
I'm sure someone who knows more than I will chime in.
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by Anti Venom:
<strong>I'm no cam expert, but I think it is because you need more exhaust duration to get out all the air/fuel that you crammed into the chamber with the power adder..</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Particularly true for a nitrous app, the pressurization of the intake for SC and turbo apps helps push the burned gases out so for those apps it's not as much of a concern. Wider LSA also helps a nitrous application to build more cylinder pressure; and similar for SC/Turbo setups
That much makes sense to me. I understand that a 224/227, 114 is going to be better than a 224/224, 114 for boost/nitrous because of that. But therefore is the 224/224 necessarily a BAD cam for boost/nitrous? I mean, compared to the stock cam? I can see where it won't be optimal, but I'd really like somethign that can run well NA or boosted. Is there a reason why a TR224 on a 114 would be necessarily "bad" for boost?
I don't think there will be enough difference N/A between a 224/224 and a 224/227, but with boost or nitrous, the split will greatly outperform the single pattern.
Just my thoughts.
Just my thoughts.
![](https://ls1tech.com/forums/images/ranks/ls1tech20year.png)
N20- More exhaust than intake duration. N20 explands a ton once it breaks aopart to release the oxygen so you've got more exhaust gas.
Supercharger- Pretty much a good NA cam will work well with a super charger. A split pattern with a 114 or higher LS will work the best.
Turbo- You need, at the very least, a single pattern cam. An inverted pattern is better. Turbo's make a whole boat load of backpressure, you don't want that exhaust open longer than the intake or reversion will occur and you will lose power. A wide LS is also good, 115 or so.
So the G5 would be pretty good for N20? It's got alot of exhaust duration right? I'm considering this cam for my H/C/Nitrous coming this fall
I dunno the specs on the G5, but a bigger exhaust duration and a somewhat wide LS is good for N20. You don't want to spray N20 out the exhaust so the LS needs to be 114 or so
If I remember correctly, the traditional split duration is good for SC/Nitrous with a fairly wide LS (114 or so as previously stated).
Traditional split duration isn't great for turbos, but there are several turbo cars that run a reverse split on a wide LS so there is more time to build boost.
I think that is correct at least.
