my cam progress pics
Old Feb 24, 2007 | 05:25 PM
  #41
99blancoSS's Avatar
try a little heat
Old Feb 24, 2007 | 05:32 PM
  #42
CASHss99's Avatar
is the pully suppose to be turning while im tightening the puller
Old Feb 24, 2007 | 05:38 PM
  #43
01ls1lover's Avatar
One of the best!
Old Feb 24, 2007 | 05:49 PM
  #44
CASHss99's Avatar
ok the pulley is moving and i kant feel my hand lol
Old Feb 24, 2007 | 05:50 PM
  #45
badaz28's Avatar
I found a longer crank bolt at an Ace Hardware store, any hardware store should have it. It didn't look the same though, it has a smaller head and I got 2 washers, so that it would be as wide as the stock one from the top.
Old Feb 24, 2007 | 05:56 PM
  #46
01ls1lover's Avatar
^ True, Try getting a threaded rod.. With a few washers to get it tight.
Old Feb 24, 2007 | 06:02 PM
  #47
CASHss99's Avatar
there closed now damnit the pully most def moved dont line up to any other pully its good i have the laptop in garage
Old Feb 24, 2007 | 06:04 PM
  #48
CASHss99's Avatar
kame lose and off yppy
Old Feb 24, 2007 | 06:07 PM
  #49
CASHss99's Avatar
i used the socket and stock bolt
Old Feb 24, 2007 | 06:29 PM
  #50
99blancoSS's Avatar
Congrats.
  #51
cowboysfan's Avatar
glad u got the pully out. before u re-install pully make sure threads are OK.
fuwerzws6
Old Feb 24, 2007 | 06:43 PM
  #52
CASHss99's Avatar
ok i have 5/16 rods ill stick those in and i should be very carefull,,,, also do i need cam lube or just use oil
Old Feb 24, 2007 | 06:56 PM
  #53
01ls1lover's Avatar
Just oil will be fine but be sure to get it inside the cam too all good and oily! remember when you start it up your engine will have no oil in it at all for a little bit untill the pump pumps it through.
Old Feb 24, 2007 | 07:08 PM
  #54
CASHss99's Avatar
ok i did the flicking of the wrist to the cam it is very very slippery to move so how do i know the lifters are up
Old Feb 24, 2007 | 07:16 PM
  #55
99blancoSS's Avatar
do the rods slide in? if so they're up
Old Feb 24, 2007 | 07:24 PM
  #56
CASHss99's Avatar
i got kut them lil shorter,,, also the oil pump do i hav eto drop the entire pan then rtv the hole thing can some one briefly explain that to me
Old Feb 24, 2007 | 07:29 PM
  #57
yak's Avatar
yak
for the pan you need to drop it as much as possible. I never put rtv on my pan when I put it back on and it never leaked. if you wanted to be safe I would put a bead on the front and the back. as for the puley when it goes back on, I heat up the inside of the pulley with a torch and then line it up on the crank and put a 2x6 over and whack it a couple times with a hammer, it almost seats itself all the way on. then just tigheten it down.
Old Feb 24, 2007 | 07:36 PM
  #58
CASHss99's Avatar
ok i kant get the rods in the block like i have no proper angle to.. the rods are bout 2 inche longer then the cam
Old Feb 24, 2007 | 07:37 PM
  #59
99blancoSS's Avatar
concur on the pan. loosen all the bolts as much as you can. The pan wont fall off the k-member is in the way. The gasket seals it you really dont have to worry about it.
You'll use some rtv in the front where it mates to the front cover just as a precaution when you put the front cover back on. The pick up tube bolt is a pia to get back in. You need to reverse your hand like you were facing backwards.
Old Feb 24, 2007 | 07:38 PM
  #60
99blancoSS's Avatar
Shorten them, or move the ac evap out of the way
