my cam progress pics
Old Feb 25, 2007 | 10:24 AM
  #81
CASHss99's Avatar
thanks bro man you know after getting that cam in i felt like a new person no im not gay but man you know you can say yea i did it. lol ima start on the oil pump soon. have to get more propane for the heater and fishing line.. also guys i had the oil filter for only 500 miles can i just leave it on for now and wait for the 100 miles after teh 1st start up to change it
Old Feb 25, 2007 | 11:24 AM
  #82
01ls1lover's Avatar
I dont see why that would be a problem.. But then again there could be something i dont know..
Old Feb 25, 2007 | 11:39 AM
  #83
MavrikTA's Avatar
Yeah, keep the oil filter you have. No sense in changin it before you put some miles on the cam. Just change your oil after 100 or so, to be safe.
Old Feb 25, 2007 | 11:44 AM
  #84
CASHss99's Avatar
i bought loctight medium strength but its blue? the ls1how to said medium red but i can find any red anywhere...
Old Feb 25, 2007 | 11:46 AM
  #85
MavrikTA's Avatar
I used blue also. Red is supposed to be 'Permenant". I didnt want to use that, because from what Ive seen here once you do one cam, you are likely to try another! LOL
Id say blue is fine.
Old Feb 25, 2007 | 11:47 AM
  #86
CASHss99's Avatar
thats what i figured
Old Feb 25, 2007 | 12:00 PM
  #87
01ls1lover's Avatar
Ya blue is the way to go!
Old Feb 25, 2007 | 12:06 PM
  #88
CASHss99's Avatar
thanks guys i really apreciate it
Old Feb 25, 2007 | 12:38 PM
  #89
CASHss99's Avatar
the oil pan any tips? i got all bolt half way so just pry at it till i kan reach the pick up tube bolt
Old Feb 25, 2007 | 12:56 PM
  #90
CASHss99's Avatar
its hard to pry off man
Old Feb 25, 2007 | 01:59 PM
  #91
99blancoSS's Avatar
make sure you get all the bolts, there's a couple horizontal ones as well. Bang it with a rubber mallet or log like I used. It'll pull down
Old Feb 25, 2007 | 02:01 PM
  #92
CASHss99's Avatar
oil pump off
Old Feb 25, 2007 | 02:41 PM
  #93
CASHss99's Avatar
how are the dots
Old Feb 25, 2007 | 03:37 PM
  #94
stangkiller2005's Avatar
looks perfect... nooooow..to get the pick up tube back on! LOL
also makre sure the gear on the oil pump is ligned with the crank gear ..if there not centered corectly u can chew up the gear on the oil pump, and lose oil pressure.. like it states in ls1how to.. ull kno when its on good cuz it will slide rite on...
Old Feb 25, 2007 | 03:42 PM
  #95
CASHss99's Avatar
the o ring keeps getting caught behind the tube what do i do
Old Feb 25, 2007 | 03:50 PM
  #96
do you have a helper? it would help to have someone help you manuver the oil pump while u get the pick up tube and o-ring on.. dont push the o ring on all the way.. just sit it over... and push the oil pump on slowly.. just making sure it goes in correctly..takes a few trys.. just take ur time.. and be patient... its one of those parts that u want to get done.. but the faster u try or more frustrated u get the harder it gets..especcialy the positions u have to get it.. i found it easiest to acutally sit on the floor facing the oil pump..scence there is nothing in front of the block it makes it possible.. well i didnt have the AC condencer either....
Old Feb 25, 2007 | 05:35 PM
  #97
tuffass's Avatar
Originally Posted by CASHss99
lol but i kant find the longer crank bolt anywhere at all...
ill look for a huge claw. in the mean time kan i change the springs right away? i probably can. i bought a 4 foot long 5 16 metal rod so ill cut that and stick it in there when i finally get the cover off
Is that for the lifters?
How much did it run you for that bar? I'm trying to get all my **** together for my swap but went to autozone for 16 pen magnets that I thought were 1.00 and he said I owed him 48.00... : So needless to say i didnt buy them.
I know the rods work a lot better but dont want to spend 90.00 on the tool and dont really trust wooden dows.
Old Feb 25, 2007 | 05:52 PM
  #98
01ls1lover's Avatar
A wooden dow should work just fine..
Old Feb 25, 2007 | 06:03 PM
  #99
CASHss99's Avatar
i need to put the timing cover back on yea
Old Feb 25, 2007 | 07:32 PM
  #100
MavrikTA's Avatar
Congrats dude. Hard part is over! Well, really, I guess the hardest part is bringing yourself to turn the ignition the first time! LOL Make sure you leave the coil packs unplugged and turn her over for a while to make sure everything that is supposed to rotate, is doing so correctly before it gets spark!
