Help me pick which heads/cam to get.
The cam specs r 224-224 581-581 113LSA
It has VERY fast ramping speeds and Julio needs to notch the pistons becasue of the .XXX milling of the head.We also have some trick gaskets I cant talk about...
We r shifting at 6600rpm
Running Stepped Dynatechs too.
Should make some about 415RWHP+ threw a auto?
My only problem is my big fat stomach and my 3550lbs car.
JS
FWIW, we had to notch the the pistons for intake valve clearance on my solid roller motor. Exhaust valve clearance was acceptable.
<strong>
I still don't understand. With a 2.055 valve, according to my math, you can only safely run a 0.560 cam on the intake side. With a 2.02 valve it's just a litte larger @ 0.570. </strong><hr></blockquote>
Jason 99 T/A pretty much covered it, but there is just to many other variables to say with xxx valve you can run xxx lift.
Heck, if I got the valve to hit peak lift at BDC I could 2 inches of lift + <img src="gr_stretch.gif" border="0"> <img src="gr_stretch.gif" border="0">
But I see the point you are making, and agree with it - when you start cranking up the duration and the lift it is deifinitely something to worry about. As long as he clays the heads to check for pv clearance they should be okay though (and fly-cut if they need to).
Chris
114LSA will idle better.
Make no mistake, 224/224//114 will lope. That is a pretty meaty cam.
Each cam is different. Some will require notching the pistons but it depends on the lift AND duration.
Totally streetable and good for a 12.1 @116 at the strip.
I'm thinking my times will be better once my new clutch is installed.
<strong>Mark, wassup. Nice pic, make me one. <img src="gr_stretch.gif" border="0">
Each cam is different. Some will require notching the pistons but it depends on the lift AND duration.</strong><hr></blockquote>
Thanks John. Maybe if you lend those tools you offered and perhaps made yourself available if I run into a snag, I could make a picture like that for you. I'll provide the beer. <img src="graemlins/gr_cheers.gif" border="0" alt="[cheers]" />
What about a 222/222 114 cam? Same power but a better chance of passing emissions?
<strong>I'm using Ka-Tech's heads/cams stage II setup.
I'm thinking my times will be better once my new clutch is installed.</strong><hr></blockquote>
They have great prices! How do you like their stuff?
<strong>Just to clarify... with this cam: 224/224/.561/.561
A 112 lsa cam makes power lower in the range and would be more likely to create traction problems (street tires) whereas a 114 lsa would make the power a bit higher up which will make it easier to hook up? Is that correct?
What are the rpm differences where the power comes in?
Which one has the broader power/torque curve, the 114?
Either one will idle fine with an M6?</strong><hr></blockquote>
Both will generate enough torque to cause traction problems.
112 LSA will probably have a hair more torque below 3000 rpm. 114 LSA will probabaly hold peak HP for an extra 200 rpms on the top.
114 will have a slightly better idle, but not by a lot.
Chris B: I think Mikey's concern was with heads milled down enough to achieve the 11.2 CR, no with milder CR's.
230/236 duration. 110 LSA.
<img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
Note that this is through a FULL single exhaust, through a 3" dynomax superturbo muffler.
Sam
<small>[ September 24, 2002, 12:48 AM: Message edited by: 280Z28 ]</small>
<img border="0" title="" alt="[Razz]" src="gr_tounge.gif" /> <img border="0" alt="[Firebird]" title="" src="graemlins/formula.gif" /><small>[ September 24, 2002, 03:09 AM: Message edited by: beardWS6 ]</small>
You would still make just as much power as the regular hammer cam (112lsa) but it'd be more spread out and a little bit higher in the rpm band.
Seems like MTI or whoever could custom grind the hammer to 114lsa.
224/224 on a 114 should pass emissions with catalytics, possibly borderline on the idle test though.
-Tony
