Installing spark plugs..& oil on threads?
https://ls1tech.com/ubb/cgi-bin/ulti...=006656#000002
I also shoot nitrous I'm wondering if I am getting blow by if there is HP being lost there also. What do you think?
Do you consider it to be a lot of oil on them?
Moving this to the internal section where you can get some better responses to this.
Eric
Spark Plug (With New Cylinder Head Installation) - 20 Nm
Spark Plug (Subsequent Installation) - 15 Nm
Nm of course, standing for Meter-Newtons! Huh?
20 Nm converts to 176.8 in-lbs, or 14.73 ft-lbs
15 Nm converts to 132.64 in-lbs, or 11.05 ft-lbs
It sounds like your getting oil up past the number 2 piston rings though - GM has a tech service bulletin concerning that.
Basically, it stated that if you run high rpms, you're going to consume oil faster. And, there's some guidelines they use to determine if it's excessive or not - like, more than 1 quart every 2000 miles, I think.
P.S.
I'm thinking I need to tighten the plugs a little tighter as I know they are get being tightened that tight to begin with.
Here's the Tech Service Bulletin:
Bulletin No.: 01-06-01-023
Date: October, 2001
Subject: Higher Than Expected Oil Consumption
(Replace Rings)
Models:
1999-2001 Chevrolet Camaro, Corvette
1999-2001 Pontiac Firebird
with 5.7L Engine (VINs G, S - RPOs LS1, LS6)
Condition: Some owners may comment on higher than expected oil consumption. When checked, the oil consumption could be in the range of 400-600 miles per quart (700-1000 km/L).
Cause: The cause for this condition may be an interaction between the piston rings and the cylinder bore in vehicles that are operated at higher RPMs - typically manual transmission vehicles driven in a manner where the engine is frequently or consistently operating at greater than 3200 RPM.
Correction: A new set of piston rings is currently available through GMSPO. The new rings are part of a complete piston ring kit. Install only the number 2 compression ring and the oil expander ring from the piston ring kit. All other rings in the piston ring kit should be discarded. The original number 1 compression ring and the oil ring rails should be re-used in their original positions on the piston. All pistons should be used in the same cylinder bore.
Important: Do not dress or hone the cylinder bore. Nothing should be done to change the bore finish for this condition. Changing the bore finish may aggravate the condition.
Bulletin No.: 01-06-01-011
Date: March, 2001
Subject: Information on Engine Oil Consumption Guidelines
Models:All 1996-2001 Passenger Cars and Gasoline Powered Light Duty Trucks Under 8500 LB GVW
Oil Consumption: The accepted rate of oil consumption for engines used in the vehicles referenced is 0.946 liter (1 qt) in 3200 km (2000 mi). This rate only applies to personal use vehicles, under warranty, maintained in accordance with the appropriate maintenance schedule, with less than 58,000 km (36,000 mi), or 80,450 km (50,000 mi) for Cadillac, driven at legal speeds in an unloaded (for trucks) condition.
OKAY, this statement has pretty much eliminated EVERYONE IN THE FREE WORLD!!!
Further down, it says this -
Measurement of Oil Consumption
2. Verify that the engine is at normal operating temperature (see Owner's Manual or Service Manual).
So, I guess everyone who has installed a lower thermostat is SOL!
I love my Camaro, BUT I HATE GM!
I just did a search in the Generation III External Engine area and found quite a few good ones, including this thread on accessing plugs 6 & 8:
https://ls1tech.com/forums/generatio...ug-change.html
but in all seriousness, if oyu have AIR and EGR, unbolt those, remose the wires (obviously) and take off your coils. if your an 98, just take off the first 2 or so. shuold have enough room for that. one of the few benifits of having a 98 ls1 lol not many lol
get as many as you can from the top. all but the last on on the passenger side can be gotten by the top. this one needs to be had by the bottom, unless you have small hands.
like i said headers makes it easier lol
just be prepared to spend an hour or so doing it.
