rebuild the LS1 or buy a pre-built short block?
I'm wanting a forged block. My goal is to someday procharge it and hit over 500 rwhp. Right now I'm sitting at 420rwhp on a stock bottom end. The only mods I have done to the motor are ported LS6 heads and a 22x/22x .581 Comp Grind cam. I've got an LS6 intake, LS6 t.b., and a few other bolt-ons.
Now... I've got a few questions...
I've got about 3,000 to spend. Let's keep in mind I'm wanting to buy a rear-end in the future.
*1* What do you think I would pay for parts and a rebuild on my block? looks like $5700!!!
*2* How much would I pay a sponsor for a budget, pre-built block? If I do this, I'd like to have it cammed, heads, and a forged bottom. edit: looks like about $6000!!!!
*3* Forged LS2 vs. Forged LS1?
*4* How much would I be able to get out of my block with it's mods? Sits at 101k.
im going through the same situation from what i have come up with a rebuild wont save you much money, parts and machine shop costs add up . a forged short block will be the best bet as far as im concerned. 3000 wont get you far either way , that will hardly buy the short block!!
![The Judge](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_judge.gif)
" 2k isn't bad at all! how much did it cost you to have the heads, cam, lifters & all installed? was the money worth it?"
$1500 from a local shop. Included modifiying the stock oil pickup, installed timing chain, worked on the heads, degreed cam, crane rockers. Not bad at all.
Hmmm I am in the same boat too.
My '99 z28 spun a bearing from the lack of oil pressure and I am determining what to do. I would like to put a forged 408, but I dont know how to go about doing it. Sorry for the hijacking. Shoud I go out and purcahse a block and build it up on a fresh block or is it worth just boring, and honing my current block and putting a forged 408 rotating assembly.???
Originally Posted by candlelit
from your mods, I'm guessing you're looking for something that can handle that turbo
what kind of power are you putting down?
