Misfires cam related?? car sputters really bad
ok guys, i went out to atap and while i was atapping something weird happened. The car just felt like it lost power. Anyway I got SES lights from misfires.
#4 is showing like 80 misfires
#6 is showing like 30 misfires under current
what gives??? I switched the plug on 4 and swapped the wires up on 2, 4, 6 and still its showing 80 in #4
the car sputters under throttle and i can tell something isnt right <img border="0" title="" alt="[Sad]" src="gr_sad.gif" />
any ideas????
any ideas????
well i just switched all the plug wires on both sides and still #4 is misfiring bad <img border="0" title="" alt="[Sad]" src="gr_sad.gif" />
i dont get it??
i dont get it??
Possible valve spring problem....
My car idled very badly when my 941 went south. Tons of misfires and an SES light....
I wouldn't drive the car much at all. How is it at idle?
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by Kenny H:
<strong>Possible valve spring problem....
I wouldn't drive the car much at all. How is it at idle?</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">idle is ok, but its still not right. Its hard to explain, but its obivious something is wrong. I can bascially only idle in and out the of the garage. Any gas and the car just sputters <img border="0" title="" alt="[Sad]" src="gr_sad.gif" />
so i guess i need to pull the valve cover on that side?? I thought these 918's were tuff
but whatever it is, im reading hellacious misfires on 4 and some on 6 <img border="0" title="" alt="[Sad]" src="gr_sad.gif" />
Pull the valve covers off and just check the springs. I had a the same problem, but overlooked the valve spring at first because I didnt here any noise. After plugs, wires etc.. it turned out that the valve spring was broke at the very top.
Just an easy check you might want to try.
John
John
when i get a chance today ill pull the cover... hopfully thats the prob and nothing else got screwed up <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
the price of trying to go fast...
any easy way to check the coil pack to see if thats bad?
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by 98TAauto:
<strong>when i get a chance today ill pull the cover... hopfully thats the prob and nothing else got screwed up <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
any easy way to check the coil pack to see if thats bad?</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">You could switch out the coil pack and see if the miss fires follow it to it's new location.
yeah i found the prob. See my 918 break post..
after i switched the wires and plugs and the prob was still there i took off the valve cover. Sure enough #4 was cracked in 2 spots!!! <img border="0" title="" alt="[Sad]" src="gr_sad.gif" />
