It's a different world above 7500!!!!
Old Aug 20, 2002 | 05:11 PM
Joe Kizzire's Avatar
Resident Grump
Default It's a different world above 7500!!!!
Spring surge..... that's what I've got. Intake valves bouncing on the seat when they close due to harmonics in the spring. This is the same valves and springs that are on the SAM 375 inch motor and it has no problems. The only difference in the motors is mine is a 6 liter block and 5 ci less. The problem didn't show up until I started turning the motor 8000 on the nitrous. It's not valve float. We'll see what's up in a few days.
Old Aug 20, 2002 | 05:16 PM
VINCE's Avatar
Shorty Director
Default Re: It's a different world above 7500!!!!
Nice..
Old Aug 20, 2002 | 05:56 PM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
Sounds like it's going to blow up and you should back it down 400 rpms. I don't think the stock pcm makes adjustments above 7200 I think it freezes and just does whatever it was doing at 7200.
I'm going to spray at TR Shootout and just take it up to 6600 on 28" slicks.
Old Aug 20, 2002 | 06:01 PM
Fenris Ulf's Avatar
Check your spring pressure and make sure they just havent weakened.
Old Aug 20, 2002 | 06:27 PM
cablebandit's Avatar
Joe how do you diagnose that? I would have NO IDEA that it wasnt valve float
Old Aug 20, 2002 | 06:38 PM
Resident Grump
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by Pro Stock John:
<strong>Sounds like it's going to blow up and you should back it down 400 rpms. I don't think the stock pcm makes adjustments above 7200 I think it freezes and just does whatever it was doing at 7200.
I'm going to spray at TR Shootout and just take it up to 6600 on 28" slicks.</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">John if it blows up I've already got another one in the oven. Also the PCM adjust right up to 8000.
Fenris the springs are OK.... done did that....
Old Aug 20, 2002 | 07:32 PM
LS1derfull's Avatar
Joe, how do you figure spring harmonics are causing seat bounce? Seat tension is what controls bounce, you might have proper open tension thats why you dont have valve float, but valve seat bounce is more likely from lack of seat tension. If im wrong im curious how you came up with this diagnosis?
Old Aug 21, 2002 | 01:47 AM
CRASH 02's Avatar
I was under the assumption that on nitrous you should shift at the same or lower RPM's since nitrous makes so much torque. If that is true. Then I would think you might be ok not spinning the motor so high.
Old Aug 21, 2002 | 02:35 AM
WMSuperSport's Avatar
I say spin the hell out of it! <img border="0" alt="[Burnout]" title="" src="graemlins/burnout.gif" />
Old Aug 21, 2002 | 03:08 AM
ChrisB's Avatar
Can you loose any valvetrain weight (Ti retainers? Star shaped retainers (crower sells them for SBC - you could convert yours with a dremel - instead of a full circle they have "notches" cut in them so they kinda look like a starfish), etc.
If it's a harmonics issue then changing the weight of the springs mass will change the rpm at which you have the problem.
A different spring will also help if it's harmonics - doesn't even have to have more pressure - just a different construction/cross section, etc.
I agree with the above though - are you sure it's harmonics? It could simply bee not enough spring pressure, or a lobe profile problem?
I would tend to think that it's a lobe problem if it's really valve bounce - remember, while your cam lobe profile has a constant radial velocity/acceleration/jerk, etc. at any given point as your rpm increases so does the factor that translates this radial acceleration to linear (what the valve sees). A profile that's good at 6000 rpm could be to agressive at 7000 rpm - infact if it's near the edge at 6k it would have to be at 7k. To agressive means it is closing the valves to fast (setting them down to hard) and the spring is weakest at this point.
Chris
Old Aug 21, 2002 | 07:21 AM
Tim98TA's Avatar
From: From the Bowels of Hell!!! You want some of me bitch?!?!?!
If I remember correctly, I think Joe runs a spring without a dampner. It's double, but without the dampner. He is changing that and installing a dampner.
Tim
Old Aug 21, 2002 | 07:39 AM
Resident Grump
LS1derful it is not valve float because the valves have not touched anything. You're right about seat tension that could be the problem. Again it's only the intakes.
Crash 02 with the gear I run it really don't matter because it's on 8000 in first gear before you can
shift it anyway.
Chris you could be right. The intake lobe profile is very agressive (254 @ .650) and the roller might have a problem following the lobe on the closing side. The heads are being worked on in Texas as we speak.... As soon as we get an answer I'll let you guys know what's going on.
Old Aug 21, 2002 | 08:40 AM
Patrick G's Avatar
LS1 Tech Administrator
Joe, this is a long shot (since you're not running stock rocker arms), but what does your rocker to retainer clearance look like? I had minimal clearance between the underside of my rocker arms and spring retainers and it was coming in contact at high rpms. Motor lost tons of power up high (just like valve float). Judson's guys clearanced the rockers and I've been able to peg the rev limiter with ease. Like I said, it's probably a long shot, but this problem absolutely kicked my ***! <img border="0" title="" alt="[Mad]" src="gr_images/icons/mad.gif" />
__________________
2013 Corvette Grand Sport A6 LME forged 416, Greg Good ported TFS 255 LS3 heads, 222/242 .629"/.604" 121LSA Pat G blower cam, ARH 1 7/8" headers, ESC Novi 1500 Supercharger w/8 rib direct drive conversion, 747rwhp/709rwtq on 93 octane, 801rwhp/735rwtq on race fuel, 10.1 @ 147.25mph 1/4 mile, 174.7mph Half Mile.
2016 Corvette Z51 M7 Magnuson Heartbeat 2300 supercharger, TSP LT headers, Pat G tuned, 667rwhp, 662rwtq, 191mph TX Mile.
2009.5 Pontiac G8 GT 6.0L, A6, AFR 230v2 heads. 506rwhp/442rwtq. 11.413 @ 121.29mph 1/4 mile, 168.7mph TX Mile
2000 Pewter Ram Air Trans Am M6 heads/cam 508 rwhp/445 rwtq SAE, 183.092 TX Mile
2022 Cadillac Escalade 6.2L A10 S&B CAI, Corsa catback.
2023 Corvette 3LT Z51 soon to be modified.
Custom LSX tuning in person or via email press here.
Old Aug 21, 2002 | 11:31 AM
Jay 95WS6's Avatar
check the retainer clearance like patrick g said also valve train mass coould be the issue try lighter valves @that rpm
Jay
Old Aug 24, 2002 | 10:26 AM
Resident Grump
Patrick checked that when the engine was built.
No problem there.
I run T&D rockers.
Old Aug 24, 2002 | 01:30 PM
One Monkey's Avatar
Joe ours runs too 8000RPM with out anysurge...
But I don't belive our springs and the 375 is the same. we are running diffrent springs ours is the same as the 418.
hey remeber that set of heads I was showing you while you where down here?? 330CFM set!!
man it's making some killer power.
Hope you get that spring line out. 8000RPM is fun.
Brent
Old Aug 25, 2002 | 02:08 AM
MY99TAWS6's Avatar
Doesn't are make that rev kit I read about..not sure if its for ls1's too or just for lt1s???
Old Aug 25, 2002 | 10:11 AM
SJH's Avatar
SJH
Joe,
what head gasket/thickness are you running?
Do you know how much quench height you are running?
Steve
Old Aug 25, 2002 | 10:20 AM
XtraCajunSS's Avatar
Joe,
I agree that changing the mass of the valvetrain components will change the frequency of the harmonics (hopefully out of your range of use) You should try the retainer'lock combination I'm using... each retainer is 4gm lighter than an equivalent non-convolouted/drilled titanium retainer plus, they supposedly allow your springs to run cooler due to the added oiling...
Shane
Old Aug 26, 2002 | 05:17 PM
java's Avatar
From: no stops signs, no speed limits .... on a highway to hell
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by XtraCajunSS:
<strong>Joe,
Shane</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">I agree, that is what someone told me to.
