which pistons? help! rebuilding bottom end
Old Aug 22, 2002 | 10:15 PM
highgmc's Avatar
Default which pistons? help! rebuilding bottom end
I ordered mti stage 2 heads and c2 cam, the heads will be milled like .30.
I need to know a price on pistons that are SAFE with the stage 2 milled heads.
I don't want issues with not being able to run pump gas, and don't want to have pistons shaved.
will I have to worry about the valves hitting the pistons? (heard something about this on here)
help me choose pistons/rings for stock bore and perhaps rods.
thanks!!!!
Old Aug 23, 2002 | 02:46 AM
AlonzoVersion 1.0's Avatar
Default Re: which pistons? help! rebuilding bottom end
Call Thunder.They know what they are doing and sense they are out of state you wont have to pay sales tax on 600 dollar items either.I would go with ross pistons but if your taking the motor apart why not just buy one or at least the block the way you want it?It would be a lot easier and you can just eat the core.
Old Aug 23, 2002 | 02:48 AM
Ooops I thought you were in Texas.Give MTI a call as well but who ever is cheaper is the way to go.I am thinking Thunder for some reason <img border="0" title="" alt="[Roll Eyes]" src="images/icons/rolleyes.gif" /> but I am only human.
Old Aug 23, 2002 | 06:18 AM
highgmc's Avatar
mti said $1100!!! for rods and $800!! for pistons! with an 8 week wait!
<img border="0" alt="[Firebird]" title="" src="graemlins/formula.gif" />
Old Aug 23, 2002 | 06:33 AM
highgmc's Avatar
will wither of these work from THUNDER?
what compression would these make with my mti heads milled .030? I want to run high octane pump gas...
JE, the leader in forged performance pistons, is proud to introduce the LS1 New Generation Small Block Flat Top Pistons that are compatible with Nitrous, Turbos and Superchargers. Pin fitting and double spiral locks are included. The valve relief in JE's new LS1 piston accommodates oversized valves and high lift cams proven by extensive R&D. No external crank trigger is required on small bore shelf stock pistons. The metric ring package provides superior seal with low drag, giving you increased horsepower. JE gives you the latest industry leading technology based on more than 50-years of experience and are used by the biggest names in LS1 engine building.
Part Number Description Price Qty
123-194883 JE LS1 Forged Flat Top Piston set w/ -2cc Valve Reliefs 3.905" BORE / 3.622" Stroke / 6.125" Rods / 1.175" Comp Height / .927 x 2.500 (118g) Wrist Pins Included
$600.00
123-194884 JE LS1 Forged Flat Top Piston set w/ -2cc Valve Reliefs 3.905" BORE / 3.622" Stroke / 6.098" Rods / 1.340" Comp Height / .945 x 2.500 (130g) Wrist Pins Included (For stock rods)
$600.00
123-N6008-3900-5 JE LS1 Piston Ring Set, 1.5mm, 1.5mm, 3mm FOR 3.905 BORE
$179.
2000 Camaro SS's Avatar
That sounds about right Terry, you might need to think about doing it for a winter project. But the prices seem the same from when I looked. As for the weight it will only be longer as more people start to re-build these cars.
Old Aug 23, 2002 | 06:35 AM
highgmc's Avatar
it's useless running 12.81! it's coming APART! hahaha more fun to work on!
Old Aug 23, 2002 | 06:47 AM
smokinHawk's Avatar
i paid about $1300 for JE pistons, Eagle rods, rings and extras.
so that sounds about right
Old Aug 23, 2002 | 08:52 AM
Paul F's Avatar
Terry we have the JE Pistons and Lunati Pro-Mod rods in stock for $1300, and the JE rings are $179.
Paul
www.thunderracing.com
1-877-516-7223
Old Aug 23, 2002 | 09:01 AM
Viper's Avatar
Paul,
Would I have to buy ARP rod bolts separately?
Old Aug 23, 2002 | 10:19 AM
Jason99T/A's Avatar
I can shift faster than you.
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by Viper:
<strong>Paul,
Would I have to buy ARP rod bolts separately?</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">The Lunati rods come with upgraded rod bolts.
Old Aug 23, 2002 | 11:08 AM
highgmc's Avatar
thanks paul, there is my choice! what kinda compression will it be with the .030 heads? safe for pump gas?
Old Aug 23, 2002 | 11:55 AM
Viper's Avatar
Great question. My motor blew up 2 weeks ago ( oil pump let loose ) and I'm in the process of discovery ( yea, like a kid in a candy store! ). I'm going to get the shortblock redone , and now I'm looking at heads and cams. So I would like the answer as well on milling .30 and what it does to the gas u can safely run. I can run 93 in Cleveland....
Old Aug 23, 2002 | 01:36 PM
Viper's Avatar
ttt
Old Aug 23, 2002 | 01:55 PM
Paul F's Avatar
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by terry99ta:
<strong>
thanks paul, there is my choice! what kinda compression will it be with the .030 heads? safe for pump gas?</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">LS1 heads milled .030 with the JE pistons I would think you would be about 10.5-10.8. Should be fine on pump gas.
Paul
Old Aug 23, 2002 | 02:04 PM
XtraCajunSS's Avatar
Terry99ta,
The best thing to do once you get your combo together is buy a Scanmaster so you can check for knock retard while you are driving. You will also see what your timing is and be able to check trouble codes. It's money well spent IMHO. I used one to determine how much race gas I had to run with my solid roller 409. I'm running 50/50 104 and 93 without problems with 12.75:1 static compression. I do have a rather large cam though so that helps. You should be ok under 11:1 with pump gas, but depending on your tuning and cam, its better to be safe than sorry.
Shane
Old Aug 23, 2002 | 02:10 PM
dug's Avatar
dug
Youre not gonna need rods. Just get some good rod bolts and the stock ones should be fine. Just inspect them closely.
Damn, since you are rebuilding your short block too bad you sold the blower. I know if wouldnt have sold the blower there would be no money for a rebuild.
Old Aug 23, 2002 | 02:16 PM
dug's Avatar
dug
Yeah
JE pistons are nice. these guys sell them too. http://www.racenet.net/
Old Aug 23, 2002 | 02:17 PM
gogogadgetcar's Avatar
My rods, pistons and rings cost about 1500. Whent with manley rods and custom wisco pistons. The custom pistons aloud me to use cheaper SBC rods. My motor is being built for boost though, only 8.5:1
Old Aug 24, 2002 | 08:56 PM
Jackyl_30's Avatar
These J&E pistons ran $950 and the Manley Pro Series Light Weight rods were $1200.
Yeah, they are worth it. <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
<img src="http://dodgetrucks.org/photopost/data/15Dsc00589.jpg" alt=" - " />
<img src="http://dodgetrucks.org/photopost/data/15Dsc00593.jpg" alt=" - " />
<small>[ August 24, 2002, 08:58 PM: Message edited by: Jackyl_30 ]</small>
