Crank bolt?
Can I just go to the local bolt company "Austin Bolt company" and see if they have a longer bolt I can use? I have the specs but wanted to know if this will suffice. Doesnt this bolt have a slot for a 1/2" drive? So it's like a socket instead of a regular bolt?
Napa had the exact same bolt, just a bit longer...which is what I used.
With that and a series of washers, it worked like a champ.
Andy1
I might be using this idea. havnt heard of it before today.
So you do actually use the stock bolt once you get the pulley all the way on, Right?
You NEVER reuse the stock bolt!!!!! If worse comes to worse and you can't get the ARP just go to the dealership and get a stock one. But don't ever reuse the stock one!
Once you set the pulley on there with the old stock bolt (to 240 lb-ft), then you remove it and install the NEW stock style, TTY bolt. Torque it to 34 lb-ft and then stretch it...
I think that's the way it goes...
