Should I upgrade head gasket and bolts with my setup
I have the TR 224/224 112 cam and I have TEA 5.3L Stage II heads coming. The heads will be milled around .005 to .010. With that I think I will be around 11.1 or .2 for compression. Are the GM head gaskets and bolts OK for my application or am I at risk of blowing these
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by FlamnTA:
<strong>I have the TR 224/224 112 cam and I have TEA 5.3L Stage II heads coming. The heads will be milled around .005 to .010. With that I think I will be around 11.1 or .2 for compression. Are the GM head gaskets and bolts OK for my application or am I at risk of blowing these</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">I would go with ARP head studs and also the cosmetic head gaskets are good I hear.
So, the studs just make for easy removal and installation of the heads? Any special tools needed to install the studs?
LS1Tech Sponsor
<strong>So, the studs just make for easy removal and installation of the heads? Any special tools needed to install the studs?</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Studs make the job a little harder(not much)I felt safer torqueing the studs down rather the factory torque to yeild.The ARP studs are also harder than bolts and are reusable.
TByrne offers head bolts that are reusable and harder. I think I may go with these if studs make the installation a little harder. Unless there is something else I am missing for why one should go with studs.
!Dial-up Director
You will need a 3/16th hex key socket to install the larger studs. Also an inch/pounds torque wrench to torque the studs to 5 ft/lbs ( 60 in/lbs ).
head stud pictures
Justin
<small>[ September 10, 2002, 02:44 PM: Message edited by: Jsears8 ]</small>
head stud pictures
Justin
