Yella Terra Rockers!!
http://cgi.ebay.com/ebaymotors/Chevy...QQcmdZViewItem
lane
I was not going to buy the ones on ebay, it is just a short cutt to what they looked like, and all.
Lane
If they are lighter isn't that a plus?? Or are they heavier?
Lane
Lane
I answered most of that question above. The Rockers are heavier than the stock pieces. If you make sure to buy good parts in the begining, you shouldn't have any trouble. If you are gunna run the aftermarket rockers, make sure you get a good spring! Skimping in that area will surley cause you problems sooner than later.
Jimbo
Jimbo
You guys are talking about how heavy they are on the high rpm side, Is it possible if you can machine some material off of them to make them lighter. Would that be a good idea or is that just out of the question????
Lane
Lane
I have asked several sources including YT for some real data such as the weight of a set but have not gotten anyone to provide that answer yet. It would also remain to be seen what the actual weight on the valve would be as no one seems to have this information either, just statements as above without data to back it up.
If in fact these rockers do turn out to be lighter than stock in total weight and across the valve side I would buy them. Hopefully as more people get them, more information will come out. Jub Jub seems to like them and thats a plus to me but I will need to see more yet.
Mark
Then I saw where Tony Mamo of AFR had used the ulta lites on a couple of his recent motor builds. I know he does spend alot of time on the dyno with his motors and only uses the parts that he believes in. That was good enough for me. Plus the YT's are only about $100 more than the rebuilt stocks but you get a roller tip, huge cross shaft for stability, and no more needle bearing in the oil pan. It made sense to me to go with the YT's for the peace of mind.
