View Poll Results: T-Rex or MS4
T-Rex
87
36.86%
MS4
122
51.69%
Custom (explain)
27
11.44%
Voters: 236. You may not vote on this poll
T-Rex or MS4
T-Rex or MS4
I have been thinking about this for awhile, I have the MS3 in my auto WS6 and I love it, I have the 228R in my M6 WS6, I want to know what ya'll think is better for my M6, T-Rex or MS4, I have a 12-bolt w/3.73 gears, but I am replacing it w/ a 9" w/ 4.10 gears, car has LS6 stage 3 heads, full-bolt-ons, and forged 346 and 228R for now. What kind of power increase should I see with either of these cams, what would be my estimated HP of both be. Sorry for all the questions I just have been wandering for awhile, which one would net me the best time in the 1/4. And would I have to flycut. I tried doing a search but it has been down for me all night
ЯєŧąяĐ Єl¡m¡иąŧøя ™
Forget about the Rex....I would go for the MS4 if I had to pick between the 2. It makes the big power with tq right behind it. The TRex seems to be more top end power, and have lower tq than you are wanting. However, I would suggest a custom grind over any off the shelf cam and a custom dyno tune to go with it. I would think that maybe a variation of the MS4 would be more to your liking.You will have to flycut depending on your heads. Need more info than just stage III LS6.
Now with the questions:
Are you running a reliefs in the pistons? What is the CC of those LS6 heads you have? Are they milled at all? Just valves? What valve size? What are you wanting to accomplish for this car? 450? 460? 475? Why do you wanna chew up all your extra power with the 9" rear?
and.....
Can I have your 12 bolt?
I also added another category to your poll.
and.....
pistons are flat-top, heads are not milled, stock height, vavles are 2.08/1.60/64cc, am hoping for 475+, some of my buddies said the 9" is a stronger rear and can take more abuse since I have a M6. For the custom grind, what would be a good cam for max HP and TQ, but fit under stock height heads without flycutting?
Originally Posted by orangeapeel
That will be determined only with measuring. You want to have atleast like .040 clearance.
I voted ms4....ppl are making some crazy power with them in cam only cars.....much less one with a good set of heads.......I was also going call dips on that 12 bolt but orangepeel beat me to it
12-bolt is already spoken for if I sell it, I might put it in my auto WS6 since it has 3.73's, and the 9" has 4.10 help me out alot since I am a m6, plus it can take more abuse.
Originally Posted by kaos_
t-rex pulls like a mother. i've nearly gotten whip lash from it. never ridden in an ms4 but doesn't the t-rex have records for fastest 1/4 cam only?
Originally Posted by Z28_DAD
i agree. i just got done with my install last friday and almost **** myself on saturday. i went from a 224 to the t-rex btw
****. i can only imagine what it feels like off the line in like, say a kenne bell ls1. didn't that thing make like 800 lbs of torque off idle in a vette?
