TR230 and milled heads
Old Sep 18, 2002 | 07:50 AM
BYBYC5's Avatar
*Bad Trader*
Default TR230 and milled heads
i just got my tr230/224 and now i have some 5.3 heads i wanna get done, , i noticed verbs milled .10 and had good p/v clearance. if i milled .10 what would the compresion be assuming stock valves and pistons, and what push rods to use..any other info i havnt asked for will be appreciated too, thnx Kevin <img border="0" alt="[Burnout]" title="" src="graemlins/burnout.gif" />
<small>[ September 18, 2002, 07:56 AM: Message edited by: Grinch ]</small>
Old Sep 18, 2002 | 08:41 AM
Paul F's Avatar
Default Re: TR230 and milled heads
You P/V should be fine with 5.3 heads milled .010. Comperssion would be about 11.0-11.2. I would use stock length 7.400 pushrods. We'll have a couple sets of 5.3 heads on the shelf in a few weeks. <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" /> Hope this helps....
Old Sep 18, 2002 | 01:59 PM
Vents's Avatar
dude, you're running more lift with the cam you have in now! you'll be fine. ;D
Old Sep 19, 2002 | 07:48 AM
BYBYC5's Avatar
*Bad Trader*
ok so what is involed besides a basic valve job to add 2.00 valves and keek stock exhaust, will there be shrouding or will it be just right or tight fit,i knoe the seat will acept a 2.02 but i want to do as little work to these as possible any help is welcome....
Old Sep 19, 2002 | 10:27 AM
gator's 99TA's Avatar
how many degrees of advance are ground into that TR230 cam? probably none?
Old Sep 19, 2002 | 01:24 PM
VINCE's Avatar
Shorty Director
It should be fine..
Old Sep 19, 2002 | 07:51 PM
BYBYC5's Avatar
*Bad Trader*
i know they will work now, my question is what do i have to do to make 2.00 valves work, as far as shrouding,
Old Sep 20, 2002 | 12:08 AM
Fenris Ulf's Avatar
Should be fine if that cam is straight up.
Old Sep 20, 2002 | 08:44 AM
Paul F's Avatar
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by gator's 99TA:
<strong>how many degrees of advance are ground into that TR230 cam? probably none?</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">You are correct, 0 advance.
Paul
