After Cam install
Old Mar 15, 2007 | 12:37 PM
dub.ya.es.SICK's Avatar
Default After Cam install
ive always ran full synthetic since ive had the car but I know regular oil is better for breaking in new parts, i just did a full cam install should i run regular motor oil for a few hundred miles than switch to full synthetic or just fire it up with synthetic? thanks ahead of time!
Old Mar 15, 2007 | 12:42 PM
PREDATOR-Z's Avatar
What you are talking about is for ring seating.
Just fire it up with your normal synth. oil. Don't forget to go through 2>3 heat cycle on the springs before going high rpm.
Old Mar 15, 2007 | 12:44 PM
brad8266's Avatar
There is no required brak in when doing a cam install. You only have to break in a brand new rebuilt engine to seat rings. Just run your usual synthetic oil.
Old Mar 19, 2007 | 09:02 AM
yea i know the ring seating process but im just wondering if it would be harmful to run some cheap oil for like 50 - 75 miles after then change it, ive heard you should change oil like 100miles after install but i dont think doing a 55$ oil change and it lasting 100 miles it worth it... or can someone explain that 100mile oil change statement or is that just hear say? i definitly want to do synthetic always but i guess im asking all about how soon to change after cam and Why? THANKS all for the replies so far, keep em coming
Old Mar 19, 2007 | 09:26 AM
MannyZ28's Avatar
When I did my cam swap, I changed my oil too 100 miles after the swap, and yeah, I did spent the money on the usual synthetic oil just to toss it out again after a 100 miles. I figured, I spent all that money on parts, I am not gonna skimp now to risk breaking any of those new parts.
Old Mar 19, 2007 | 09:34 AM
PREDATOR-Z's Avatar
That is just hear /say. I change my oil upon completion of project and that is it. Also switching back and forh from synth to non etc... that is not a good idea.
Old Mar 19, 2007 | 09:36 AM
warp_6's Avatar
I'm going to be putting a Lunati cam in in April. The want you to change the oil & filter after the first run (2000 for 20min, 2500 1min, 3000 1min, then back down to idle in 500rpm increments held for 1 min. to idle).Sound like a ring breakin/seat procedure to me , but thats what they say. The also want you to change the oil & filter again after 500 miles. Then after a total of 5k you can use synthetic again.
The instruction (destruction) sheet is also kind of generic (hydrolic, solid, roller flat tappet. Maybe why the breakin is so ****. Couldn't hurt.
Old Mar 19, 2007 | 09:38 AM
brad8266's Avatar
Well that may be for a solid system, our hydro valvetrains dont really need a break in or oil change soon afterwards.
Old Mar 19, 2007 | 10:06 AM
sweet so i needed to change my oil anyway im just going to do synthetic, but how long should i use it? the usual time or change earlier? thanks so far fellas
Old Mar 19, 2007 | 11:21 AM
PREDATOR-Z's Avatar
The usual time is fine.
