How many have idle problems after new cam?
Yeah, I know, I should just be happy I don't have this problem, but I'm just curious why I don't have this problem. Thinking that it may be tied into lower power #s. Just wondering if it's everyone besides me that has this.
I made the poll sort of flexible, check as many boxes as apply.
<strong>I keep reading about all these people who have to drill holes in the TB or bump up the idle speed to get their cars to idle right, but I've never had to do any of that. I have the TR224 cam with ARE S2 heads, no holes in the TB, idle is at 725rpms (according to LS1 Edit), and I can't remember my car ever dying even once. It does on occassion search for the idle, like after you come to a stop hard and throw it in N, and the idle will go down to 400-500rpms and go back up, and do that once or twice.
I made the poll sort of flexible, check as many boxes as apply.</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">No option for Reverse split cams.
I have an idle problem because I have an aluminum flywheel and big cam. Not enough inertia when I start up the car. Only lasts for about 15 seconds or so, but then I have to watch it for the first few minutes driving as the car likes to stall when I slam on the brakes and engage the clutch.
now im at 900rpms and 15/16th hole drilled and still i have a little prob at startup. I have to baby the gas for about 10-15secs then its fine, but still looks for idle for about a minute. Then it idles fine
There are many more variables that must be considered when answering this poll. If one car is an A4 with a stock converter with a 226 degree cam, You can bet it wont idle well, especially if it has a tight LSA. On the other hand, If it has a wide LSA, a 4,000 stall converter and the idle speed was raised to 900 with LS1 edit, It will idle fine. The same cam, installed in a M6 car might on the other hand idle just as well as the modified A4 car.
